06-15-2020, 02:06 PM | #1 |
Drives: Camaro ss '10 Join Date: Jun 2020
Clicking or cluncking noise coming from the driver rear tire
Guys i hear a weird clicking noise coming from the rear tire from the driver side
And everytime i take the car to a mechanic the noise disappers as soon as i jack the car up it disappears for 2 to 3 days and comes back again. Can you guys help me by telling me where is this coming from |
06-17-2020, 08:04 AM | #2 |
Same here, 2012 ss.
06-17-2020, 12:32 PM | #3 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
I had a TPMS sensor get loose and do something similar to that.
830 WHP 700 WTQ, Whipple 2.9 @ 13lbs Boost, Flex Fuel Tune by Blevins Tuning, LSA SBE, 3.5 GripTec, ATI LS3 Damper, AFR 260cc Mongoose, ARP Studs, Yella Terra Ultralites, Johnson 2110R, BTR PDS Stage 3, Melling 10355, Improved Racing Baffle, ID1050X, DSX Triple Fuel Pump, RotoFab CAI, NW 103mm TB, Stainless Works 1-7/8" LTH to 3" Speed Eng w/ X-pipe to NPP, Powermaster 9509 XS, Detroit Speed Motor Mounts, MGW, Monster LT1-S, ZL1 Calipers, DBA Rotors & Pads, Bilstein B6 Struts & Shocks, BMR 1.25" Drop Springs & Adj Rear Bar, Pegasus Solid Bushings, Z/28 Wheels, other misc parts.
06-17-2020, 05:36 PM | #4 |
It's the axles tweaking in the bearing, or the bearing(s). tighten the nut or replace the
rear wheel bearings. IT can also be the CV joint(s). When I changed the rear wheel bearings, mine went away. "tink" |
