Old 01-26-2022, 07:23 AM   #15
gblaue
gblaue's Avatar
Drives: 2017 Bright Yellow ZL1 6spd
It sounds like your clutch isn't fully disengaging. I had this same issue with an Integra Type R. If the pressure plate is ever so slightly dragging, it will make it difficult to get into first gear at a full stop. First gear is not synchronized, so there cannot be any force being applied to the input shaft. In the case of my Integra, a piece of the hub had broken off, and occasionally would find a happy place to cause not a complete disengagement. If it's happening to you constantly, I'd look at the clutch master or slave cylinder. Try a fluid flush first.
2017 ZL1 Bright Yellow w/ black center stripe, 6 speed, CF gas door, PDR, Navi
gblaue is offline   Reply With Quote
