Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > Exterior Parts & Accessories
Old 01-17-2022, 04:12 PM   #1
RPIDon
RPIDon's Avatar
Drives: Camaro
Send a message via AIM to RPIDon
2016-2019 Camaro 6th Generation Interior Windscreen For Convertible
If you love cruising around in your 2016 through 2019 Camaro convertible but all of the buffeting and when noise is driving you nuts this interior windscreen is just what you need to fix that problem. This genuine GM interior windscreen quickly and easily installs behind the front seats of your Camero and effectively blocks the turbulent air from blowing back through the passenger compartment of your car making your drive more enjoyable. This interior windscreen is a non-permanent designed that will allow you to quickly and easily install or remove it depending on your needs for the vehicle. When not being used this windscreen folds up in stores in a small vinyl bag featuring the Camaro logo so it can store safely out of the way and always be handy when you need to use it. Because this product is designed and built by GM you will not have to worry about it not fitting your car. If you don't drive your Camaro convertible with the top up because the wind blowing around in your passenger compartment install this interior windscreen and enjoy driving your convertible with the top down again.
Fitment: 2016, 2017, 2018, 2019 Chevrolet Camaro
RPIDon is offline   Reply With Quote
Old 03-31-2023, 03:00 AM   #2
RPIDon
RPIDon's Avatar
Drives: Camaro
Old 04-08-2023, 05:31 AM   #3
RPIDon
RPIDon's Avatar
Drives: Camaro
Thank You for shopping at https://www.rpidesigns.com/shop/item...r-convertible/
