01-27-2021, 09:25 PM | #1 |
Drives: Camaro SS 1LE Join Date: Aug 2018
Change Engine Oil Soon
I had been wondering when/if I would get a prompt like this and it finally happened, with 6% oil life left. I’m a bit surprised it didn't turn on sooner. Barely have 3k miles on the current oil so I’m not in a rush to change it. It has almost been a year though.
01-27-2021, 09:27 PM | #2 |
2020 Shadow Gray 2SS
It is a calculation that is based on driving and time, basically I have heard you could change the oil, let the car sit for a year and start it up and oil life remaining would be close to 0%...
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... |
01-27-2021, 09:38 PM | #3 |
Yep, time can be killer, if you don’t drive it much. By the time I’m at 2700 miles ( currently 2600), I’ll be on my second oil change. 30 quarts of oil will have come and gone since she was built, March of 2019.
01-27-2021, 10:23 PM | #4 |
I'm getting ready for the last 10 qts of the 30 qts I originally bought, I have 3,484 miles and the car is exactly 1 year old since delivery... I changed at 505 & 1,500 miles... This one will be somewhere between 3,500 and 4,000 miles, but the oil life indicator is ticking down based more on time than mileage/driving...
01-27-2021, 10:37 PM | #5 |
It will be okay to wait a little longer to change the oil. I usually wait until mine displays 0% to change the oil in my ZL1 and haven’t had any issues yet. Knock on wood of course!
01-27-2021, 10:57 PM | #6 | |
01-27-2021, 11:07 PM | #7 | |
01-28-2021, 06:22 AM | #8 |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
Yep, I just reset it until I get to it. Typically only drive about 2-4k/yr. Only put about 500 on this past year.
01-28-2021, 06:35 AM | #9 | |
Hot Camaro
I did mine at 629 (I was shooting for 500 but obviously missed) and again at 1659. I saw no shiny, sparkly stuff in the oil so I moved on and called it good. Replaced the filter both times. One oil change was with Mobil 1 5W-30 dexos1 and one was with Kirkland 5W-30 dexos1. I only drive on the street and will continue to use the Kirkland oil as it's about 1/4 the cost of the 0W-40 dexos2 that's necessary for track use in the LT1 motor. Oil and filter runs about $35 for me. |
01-28-2021, 07:30 AM | #10 |
01-28-2021, 09:50 AM | #11 |
Drives: 2021 Camaro SS 1LE Join Date: May 2009
My Camaro will do the same thing. I NEVER reach the mileage mark for an oil change on my Camaro or my Trans Am. I change oil & filter at or before the 1 year mark no matter what. Oil and filter are cheap maintenance and I believe EXTREMELY important to the engine health.
2021 Camaro 1SS 1LE - Red Hot
2015 Camaro Z/28 - Red Hot 2001 Mecham Trans Am #3 - 7.0L LS1 |
01-28-2021, 10:07 AM | #12 |
Drives: SWXXZL1 Join Date: Jul 2020
Send a sample of your oil to BLACKSTONE LABORATORIES.
https://www.blackstone-labs.com/?ses...h432k%29%29%2F
"Joe" does a hilarious impression of a slinky toy on stairs.
01-28-2021, 10:15 AM | #13 | |
Hot Camaro
Don't get me wrong... there are useful reasons to have oil analysis done. But, spending an extra $30 on top of what might already be an expensive event brings zero benefit unless you have something specific that you're looking for. Annual oil changes are necessary because there are just far too many contaminants (including moisture) that can make their way into the oil over a full run of seasons, especially with low overall driving use. Additionally, oil analysis is historical (backwards-looking) and not predictive (forward-looking). It can help you to know about what may have already happened but can not tell you whether something would happen in the future. In other words, it could tell you what amount of moisture has been able to make its way into the oil in the past year but can not tell you if that's what will happen in the coming year. Neither does it tell you whether you should allow the oil to remain in the car for an additional specific amount of time because oil that has started to wear / break down may absorb moisture at a faster rate than "new" oil. $30 for oil analysis is reasonable, but is 100% wasted money if you own the LT1 motor and don't track the car because that's what it costs to do an oil change with 5W-30 dexos1 oil. |
01-28-2021, 10:25 AM | #14 |
Don't lecture. It was a suggestion if an owner is concerned about 'bad' oil remaining in their engine beyond the OLM reading.
Some owners still think changing the oil at 3000 miles is necessary. It's not with synthetic oil. Spend your money in any manner you want.
