08-25-2021, 06:14 PM | #1 |
Drives: 2017 Camaro SS, 2011 Corvette GS Join Date: Feb 2019
1LE Wheels On 2SS Camaro?
Pretty sure that 1LE wheels will fit on a 2SS Camaro. But could someone please confirm this?
And will there be any recalibration of speedometer needed? Contemplating getting a set of 1LE wheels and just want to make sure they will fit be for I plop down a significant chunk of change. Thanks. |
08-25-2021, 06:15 PM | #2 |
yes they will fit no problem
08-25-2021, 06:40 PM | #3 |
Here you go.
08-25-2021, 06:41 PM | #4 |
Drives: 2014 2SS/RS 1LE Camaro&16 Silverado Join Date: Aug 2013
Yes, but 1LE wheels are offset so keep in mind you will not be able to rotate them.
I have a 1LE. Sent from my SM-N950U using Tapatalk
Z28 Brake ducts, CAI & Tune
"Never let fear decide your fate!" |
08-25-2021, 09:05 PM | #5 |
Drives: On Hiatus Join Date: Apr 2020
08-25-2021, 09:37 PM | #6 |
Drives: 2018 2ss m6 Join Date: Aug 2021
I’m trying my best to find a set of Oem 1le wheels in really good shape and not having much luck. Already bought some new SC3’s and ready for wheels. The MRRs are nice, but really want oem
08-25-2021, 10:03 PM | #7 |
Drives: blue velvet Join Date: Jul 2018
08-26-2021, 05:38 AM | #8 |
08-26-2021, 10:01 AM | #9 | |
Nannies will be happy (front to rear ratio will only change by -2.2%), speedo will be slightly off as this combo is shorter, see below. You can go up to 315 wide in the rear to offset that a little if you want, but probably not worth it.
09-10-2021, 07:56 AM | #10 |
So purchased a used set of OEM 1LE wheels from the classified's section. Not perfect as the wheels have some curb rash but my car is not perfect either. Came with a set of Michelin Pilot Sport 4S tires with 60 to 70% tread remaining.
Put the wheels on last night. These wheels are awesome and really make the car look even more badass. Car seems have a more comfortable ride also. Not sure if its the lower pressure (32 psi vs 35 psi) or that I am going from RunFlats to non-RunFlats but it is nicer. |
09-10-2021, 09:21 AM | #11 | |
Drives: 2019 Chevrolet Camaro 2SS Join Date: Jul 2019
09-10-2021, 01:26 PM | #12 |
09-10-2021, 01:55 PM | #13 |
Badassery to the gills You bet the ride is better on non-runflats, even despite having less sidewall.
You might want to do one more thing, now that you have a front splitter, remove those eyesore ugly rubber air diverters from underneath the front bumper.
12-27-2023, 06:39 PM | #14 |
Drives: '23 1SS Sharkskin A10 Join Date: Sep 2018
I know this is an old thread, but I have a question. Thinking of getting a set of MRR replicas, but it appears that the new 1LE setup created a slightly larger gap between the top of the tire and the top of the wheel well, as opposed to the stock SS setup?
