06-14-2019, 11:40 PM | #1 |
Drives: 2019 Camaro Zl1 A10 w/ Nav & PDR Join Date: Feb 2019
SS to 1LE Brake upgrade performed and this is happening now ...
I had the OEM 1LE Rotors turned (big mistake???) and put on new powerstop pads for the 1LE; broke them exactly as advised and the rotors had grooves in the by the time I got home 10 miles later. They're now worse than ever looking 500 miles later and starting to squeal, vibrate, and make chunky grabs / noises. WTH have I down wrong?? All because of the turned rotors?
I really wanted drilled / slotted / low dust rotors for the 1LE brakes but could not find; suggestions please? Also - what is the part number of the shield the goes behind the front rotors on the 1LE? Cannot find that anywhere either |
06-15-2019, 12:29 PM | #2 | |
Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
GM used to put cheap , thin rotors on in the C5 Z06 days. I warped those rotors within 1K miles on all 3 C5 Z06's I had. They all got upgraded to the BAER Eradispeed rotors, problem solved. NEVER turn rotors, spend the money and buy new ones, less headaches and issues.
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
06-15-2019, 04:41 PM | #3 | |||
Drives: 2017 1SS 1LE Join Date: Jun 2016
L - 23336594 R - 23336595
2017 SS 1LE.
