03-29-2019, 09:38 AM | #1 |
Drives: Summit White 1LT RS I4 M6 Join Date: Oct 2016
Tachometer not working
Hello all,
My Tachometer stopped working last night. The needle will go an initial spin while starting the engine, like other dials, but will not raise after that, will stay at 0 RPM. all other gauges in the cluster work fine. Any thoughts or has anybody faced similar issues? My car is a 2016 2.0T MT, it is still under warranty and I have an appointment with the dealership on Monday. Would like to know if this is common or mine is one odd case. Thanks,
2016 1LT RS Summit White M6 10/2/2016 - 3 Miles on ODO - Delivered 11/1/2016 - All around light Black out kit from Phastek 11/15/2016 - OEM Splash guards and all weather mats from ShopChevyParts.com 12/16/16 - 977 Miles. Borla S-type Axleback Planned - CAI Injen, hood wrap, Sema rocker stripes, Sema trunk balckout, Caliper Paint, Reverse LED |
04-06-2019, 09:38 PM | #2 |
Drives: 2016 2SS Glacier White Convertible Join Date: Jul 2016
I have noticed mine bouncing around every now and again. I have also noticed the oil pressure gauge do the same thing once in a while on cold start. Wonder if mine is going to stop working too.....
16 2SS SUMMIT WHITE / NPP / MRC / 6MT / CONVERTIBLE / TINT / SPLITTER / SPLASH GUARDS / WHITE KNEE PADS / WINDSCREEN / BLACK BOW TIES / HASH TAGS / DIODE DYNAMICS / GM SMOKED TAILS / MORIMOTO / ALPINE / HERTZ / BLENTMOUNT
04-07-2019, 01:53 PM | #3 | |
EMERALD COAST CAMAROS
Drives: None Join Date: Feb 2010
06-04-2019, 05:11 PM | #4 |
Drives: 2019 2LT 1LE V6 Join Date: May 2019
Mine too - brand new 2019
On drive home from work my tach stopped working. Tried several restarts with no luck. Gauge sweep on startup works fine then it returns to zero and just sits there. Brand new 2019 2LT 1LE V6 with 630 miles on the odometer. Will check fuses and hope it's a fluke. Don't want my dash torn apart and put back together this early in the life of my car. I'll be hearing dash rattles for the rest of my ownership - be they deal of imaginary.
06-11-2019, 07:59 PM | #5 |
I have noticed mine bouncing around from time to time as well.
06-11-2019, 08:42 PM | #6 |
Soon to be Millionaire
Drives: Blue 2016 Camaro Join Date: May 2016
I had this happen a couple times. They reset it and then tried a reflash. It hasn’t happened in a while but I know they didn’t fix it permanently
I run a Drone Service Company in Gainesville, FL - Please visit my site and take a look |
09-01-2020, 11:02 PM | #7 |
Drives: 2017 2LT RS Join Date: Nov 2018
Does anybody else had this issue? How to fix it?
09-05-2020, 08:03 PM | #8 |
Drives: Chevy Camaro 2SS Join Date: Sep 2020
Dude you have hypo tach syndrome and I currently have hyper tach syndrome. I can be sitting at a red light with my foot on the brake and it starts bouncing around 3k - to 5k - sometimes on the freeway let off the gas and get the tach bounces to 7k like a dang ping pong ball. The told me no tsb and start with replacing the batter ground cable because the resistance was out of spec and they didn’t even know if that would fix it. I said the cluster has no other issues and both the hud and tach reflect the same bouncing value. Let me know as well....where does it read from on both the analog cluster tach and digital hud tach because it has nothing to actually do with engine rpm. Craziness
09-05-2020, 08:40 PM | #9 |
Drives: 2016 Nightfall Metallic Grey 2ss Join Date: Oct 2017
Check the 13mm ground on the back of the head
09-07-2020, 12:37 PM | #10 |
My tach completely stop to work. Before i start the engine, gauges testing without any issue, but after i start engine, RPM gauge is dead. Dealer can't find a reason, any ideas?
