03-18-2019, 06:06 PM | #1 |
Drives: garnet red Join Date: Oct 2016
Recall camaro
anyone do their recall yet for the 2016-2018 power steering assist? Unfortunately it affects my camaro...never had any problems with my camaro. my car runs great! I have never personally dealt with a recall before on any car that I have owned...is this bad? what happens if I go to the dealer and they screw up my car? how hard is this to fix? kind of nervous...can I ignore a recall? do I have to do it? any help/advice from camaro forum would be greatly appreciated...
03-18-2019, 06:54 PM | #2 |
Drives: '18 Camaro SS Redline, '20 Bolt EV Join Date: Jul 2018
It’s no different than having any other repair done.
03-18-2019, 07:57 PM | #3 |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
takes about 4 hours. I couldn't even tell they did anything except for the big grease print on the trunk from unhooking the battery.
03-18-2019, 10:41 PM | #4 |
Drives: '17 2LT/RS 2.0T M6 50th Anniv Vert Join Date: Feb 2019
Not sure if your recall for Electric Power Steering is the same as my 2017 Camaro.
There isn't a remedy yet for mine. More details were posted on the NHTSA website today: https://www.nhtsa.gov/recalls?nhtsaId=19V086 |
03-19-2019, 08:37 PM | #5 |
Drives: '16 Camaro SS 6 spd manual transm. Join Date: Aug 2012
If your car has the takata air bag recall take it to the dealer to fix it, is a very unsafe issue
'16 Camaro SS
Prior cars: '14 Corvette C7 Stingray Z51 '14 Camaro ZL1 w/. Recaro seats '11 Mustang GT 5.0 w. track package '02 Porsche 911 Carrera '05 Infiniti G35 coupe sport |
03-19-2019, 08:48 PM | #6 | |
Drives: 2017 Camaro 2LT RS 3.6L Join Date: Mar 2016
03-19-2019, 08:57 PM | #7 |
Drives: '17 Camaro 2SS & '99 Camaro Z28 Join Date: Feb 2014
Its really about time GM owned up to this. It was a very dangerous issue.
Here's a question.... I had a long run-around with GM to get this issue fixed and it ended with them replacing the steering rack. Technically they haven't confirmed my vehicle to be effected yet BUT...if they did...should I get it fixed twice? |
03-19-2019, 11:19 PM | #8 |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
The new recall is apparently about power assist failing. So weak low speed steering assist. Not a huge deal really. Unless it can fail in other ways not mentioned in the press.
03-20-2019, 08:57 AM | #9 |
I thought the recall was for a bolt swap due to potential failure from corrosion. if the bolts are badly corroded it may require replacing the whole unit. Otherwise you get new bolts and they apply "sealant" in the area.
03-20-2019, 09:25 AM | #10 |
https://www.motorauthority.com/news/...eering-failure
pretty sure the bolt thing is a completely separate matter that may or may not be elevated to a recall yet. Last edited by cellsafemode; 03-20-2019 at 09:37 AM. |
