Old 03-18-2019, 04:19 PM   #1
2018Redline1SS
Drives: 2018 Chevy Camaro 1SS Redline
2018 Redline 1SS 0-60 time
Finally, in my second season, my 2018 1SS 6 speed manual layed down a 4.2 second 0-60 time, beating the published time of 4.3 - all stock on pump gas.
Temp was 46 degrees, less than 1/2 tank of gas, eased off the clutch with
very limited spin ramping up fast to full throttle. Car was in sport mode with traction control on. Tires showed normal temp.
Sorry one pic is sideways.je
2018Redline1SS is offline   Reply With Quote
Old 03-18-2019, 05:18 PM   #2
srcstc
Nice. Where do you see the tire temp? I've only got tire pressure.
srcstc is offline   Reply With Quote
Old 03-18-2019, 05:32 PM   #3
Azerlazer26
Azerlazer26's Avatar
Drives: 2018 Camaro 2SS
It’s under the performance tab in the gauge cluster. If it’s now showing up go in the settings and you can unlock it from there.
Azerlazer26 is offline   Reply With Quote
Old 03-18-2019, 06:14 PM   #4
Scraps0f
Drives: 2018 NGM ZL1
I have often wondered if our TPMS is good enough for actual temperature readouts and if there was a way to mod the computer to show this instead of just the ranges that are programmed.
Scraps0f is offline   Reply With Quote
Old 03-21-2019, 07:51 AM   #5
srcstc
Mine (2016 2SS) doesn't have that page. Must be something they added starting with the 2017 MY
Old 03-21-2019, 09:34 AM   #6
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
My 2016 has it.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 03-21-2019, 10:22 AM   #7
srcstc
My 2016 has it.
I'm referring to the tire temperature.
Old 03-21-2019, 10:38 AM   #8
MATEOLT1SS
MATEOLT1SS's Avatar
Drives: 2019 Camaro 2SS 10-speed
I've tried it once in my 6 speed and got a 4.7. Nice run!
MATEOLT1SS is offline   Reply With Quote
