10-02-2018, 11:22 PM | #29 |
Drives: 2001 Onyx Black/Ebony SS. 427/M6 Join Date: Apr 2016
Smart Charging system....
10-03-2018, 07:54 AM | #30 |
Drives: 2018 Camaro ZL1 Nightfall Grey Join Date: Jun 2015
An inexpensive first attempt would be to change the battery,
I had a 5th gen that did exactly what youve been experiencing, I believe the car sat in the dealers lot and the battery discharged over time, rather than replacing it, they charged it after it sat depleated. Batteries don’t do well if they are allowed to run below a certain voltage. I replaced it and all things were back to normal. Might be worth a try
1100 - 10/28/17 Ordered
1100 - 02/02/18 cancelled, Re-ordered from BeckyD 1100 - 02/02/18 | 3400 - 02/14/18 TPW 2/19 2000 - 02/06/18 | 4300 - 02/20/18 Built 3000 - 02/07/18 | 5000 - 03/08/18 At Dealer 3100 - 02/09/18 | Delivered |
10-03-2018, 09:54 AM | #31 |
as previously mentioned replace the battery. keep the new battery on a tender if the car will sit for a period of time without being used.
2016 NFG 1SS A8
10-03-2018, 10:14 AM | #32 |
I agree. I would want to try a known good battery to eliminate that as a possible source.
Pray for that to fix it. If that's not the problem, the rest of the behavior sounds like an intermittent electrical problem, and those are notoriously hard to find. |
10-03-2018, 10:17 AM | #33 |
Retired from Car mfrs....
trust me, its not the batt, its “satan in the wiring harness”, as BMW techs call it in service training.
10-03-2018, 10:22 AM | #34 |
Bannable
C6 corvettes suffer pretty bad from parasitic loss. It is the onstar system that does it on those. I removed onstar system and it cured mine.
One must forego the self to attain total spiritual creaminess, and avoid the chewy chunks of degradation
2017 ZL1 A10 - Hyper Blue Metallic Rotofab CAI, TM ported TB, AWE non res touring catback with PLP's |
10-03-2018, 11:12 AM | #35 |
Drives: Tesla M3 LR-AWD [Former 1SS owner] Join Date: Jan 2018
I've seen batteries do strange things. I had one go out like a switch without warning. No hard starts or anything. The engine tumbled strong the day before, and the next it was dead. I refused to believe it was battery, but it was.
10-03-2018, 11:51 AM | #36 |
Drives: 2017 Camaro Join Date: Mar 2018
I'd be willing to bet that's exactly it. They are constantly doing on board diagnosis of your car, even as little energy as that takes it still is a slow drain. Plus the OP doesn't drive it much by the mileage so it's probably killed the battery.
10-03-2018, 06:19 PM | #37 |
Drives: 2017 HBM 2LT RS Convertible V6 A8 Join Date: Jan 2018
Thanks GrimReaperSS! That's a lot of information to get through.
10-03-2018, 06:29 PM | #38 | |
Easy to say "just buy a new battery" but the one I have is still under warranty, and a new one costs over 150 bucks. |
10-03-2018, 09:01 PM | #39 |
This is the conundrum. You are at the mercy of the dealer. My thinking is if you replace the battery at your own expense at least you can then move on to having the dealer replace modules at THEIR expense. When you start talking about things like BCM and Infotainment I bet you start near the $1000 mark.
10-04-2018, 10:36 AM | #40 |
Drives: 2018 camaro 2 ss Join Date: Feb 2018
Pm sent to17rsvert.
11-30-2018, 08:50 AM | #41 |
Drives: 16 Summit 2SS, 92 Arctic Formula Join Date: Dec 2017
Mine just did this. It happened on the 19th and just happened again this morning. I will be replacing my battery this afternoon. This is now the 4th time it's happened in a year. Starting to loose hair when i drive the car paranoid it will happen again at any time.
2016 2SS / Summit White / Adrenaline Red / MRC / NPP / CF5 / 5LQ 6 Piston front brakes with slotted & vented 2 piece rotors / A8 / Satnav / Low Gloss Black 5 spoke
12-25-2018, 08:52 PM | #42 | |
Drives: Wife's 14' IS 250 Join Date: Mar 2014
I had my original stock battery replaced 16months after delivery. It left me stranded. It’s now been almost 1 year & now I’m having driver window & seat memory issues & car struggles to start. Bumper to bumper warranty is now over (44k miles), so I’m hoping replacing battery will fix me up.
-11% tint all around Ordered • 2/06/16 Built on • 3/22/16 Adopted • 4/07/16 Sold on 2/05/16: 2014 Camaro SW L99, 2SS, RS, NAV, Inferno Orange Interior: -Borla ATAK catback -Range AFM delete -15% tint all around -Red LED interior bulbs -55k white Cree LED fogs -License plate LED bulb swap -12" Sub Kit, BA amp swap -Oracle ghosted LED sidemarkers |
