05-08-2022, 10:09 AM | #15 |
GPI Sales Consultant
Turn the launch and traction control off - once the car is modified much they don't work like they are supposed to, and you're better off managing power with your right foot.
GPI Max Package 2.0: Brodix BR7 heads/GPI porting, MAX3 cam, ST2116LSR, BSR Max Lift rockers, LS7 LSXR with 103mm TB, Vararam OTR, Mcleod RXT, G-Force/Strange 9" IRS setup with 4.63 gear. 551whp, 11.1@124mph.
Got a question about a GPI product? Feel free to shoot me a message! |
05-08-2022, 10:41 AM | #16 |
05-09-2022, 11:35 AM | #17 |
Served USN - Atomic Chimp
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10 Join Date: Jul 2012
Slipper Clutch is different than a Clutch Slipper.
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
05-09-2022, 03:10 PM | #18 |
Oh boy, guess I'll stay outta this one. Was just trying to help.
05-09-2022, 04:41 PM | #19 |
Appreciate it. Here is the clutch slipper setup I'm trying, along with an LPE CTAP (not pictured). The controller (on the left) goes under the dash. The manifold and solenoid (as shown on the right) go in-between the clutch master and slave cylinder.
05-10-2022, 08:26 AM | #20 |
Cool thanks for the education sir! Learn something everyday on here. Appreciate you not flaming me. lol.
05-17-2022, 10:28 AM | #21 | |
10-07-2022, 11:45 PM | #22 |
Drives: 2010 1SS LS3 Join Date: Aug 2019
Did you get it installed yet? I just bought one. I had an idea for one, but it didn’t work like I had hoped. Bangshift device is well engineered.
2010 CGM 1SS
408/4L80E/ZL1 ESS G4 |
10-08-2022, 05:35 AM | #23 | ||
Drives: 2010 2SS LS3 and 1978 STROKER 383 Join Date: Feb 2018
,,remove the clutch pedal/starting interlock" Can this be done...? Eliminate the need to depress the clutch pedal when starting the engine...? Every time I start the Camaro and imagine what's going on with the thrust bearings on the crankshaft, I curse the idiot who came up with this and imagine chasing that guy around the block trying to break a fence post on his back ...as if this safety element could not be made on the brake pedal instead of the clutch.
My life is a constant struggle with Camaro.
K&N CAI, Stainless Power longtubes, high flow cats, modified Ragazzon High Performance axle back, Soler Performance ported throttle body, Soler Performance throttle controller, RAM clutch adjuster, modified LS7 clutch kit, Tick Performance billet bearing support, Tick Performance remote bleeder, separate clutch reservoir, BMR trailing arms, BMR toe rods, Pedders Suspension cradle bushing inserts, Control Arm Bushings, Strut tower brace, oil catch can, Hurst T-handle shifter, 20mm wheel spacers, DBA brakes, QTP Cutouts, Dynosteve tune. |
10-08-2022, 07:32 AM | #24 | |
It don’t come easy.
Did a search and came up with this thread. This is on a V6 but, I’m guessing it’s the same on the 8, as well. Just an FYI. Clutch Switch
10-08-2022, 09:02 AM | #25 | |
10-08-2022, 10:57 AM | #26 | |
Sorry, I didn't write it all. If I understood it correctly and translated it from English to Czech, it can be done using the HP tuner...?
10-08-2022, 11:04 AM | #27 | |
I don't have a problem with it and I will tell my girlfriend so she knows what has changed and it will be fine. And it also works via the HP Tuner, if I understood correctly..?
10-09-2022, 07:00 AM | #28 |
Drives: 2014 1ss camaro Join Date: Jul 2017
acammer, how do i delete the clutch switch. i hate that thing. nobody drives but me. ive driven sticks so long that everytime i get in i check the stick for neutral even before the keys go in. old school never had it. i had a 4th gen i got rid of the switch. can i just jump it out? why is can bus a factor third wire just a monitor? did you use something like hp tuners? i have the service manuals for my car. i dont see how it would effect can bus operations. please advise. that v6 link was just opinions no real knowledge thanks in advance. the oldman.... p.s. ive been wanting to do this since i bought the car 5 years ago
