07-18-2017, 12:19 PM | #15 |
Drives: Summit white 1le ss Join Date: Feb 2017
Just reached out to alky control... they advised that you shouldn’t run 50/50 on a pod blower due to possible cause of damage
07-18-2017, 12:29 PM | #16 |
Drives: 2001 Audi TT, 2016 Camaro Join Date: May 2016
Just another point. Alcohol burns with a colorless flame. I still have a small scar from a burn I got in the lab when I was younger. So, yeah, I'm biased, but it is something to be aware of. If you do this, stick with washer fluid since its not flammable and easy to find if you are on the road.
I ran water/meth on my Audi TT and finally took it off after two years of use due to failures of pumps (2) and switches. Not worth the hassle to me. Also, 100% meth requires a tune dependent on the meth. Run out of meth and you have a problem. Last edited by Atomic Ed; 07-18-2017 at 01:08 PM. |
07-20-2017, 10:01 AM | #17 |
Drives: 2016 M6 Hyper Blue 2SS Join Date: May 2016
Biggest Con is if the pump dies or you catch a break in the line and your tuned on a straight meth tune, you will for sure break something if your not paying attention. Have something to monitor everything and warn you if something happens. But that is where a scan gauge comes into play. Which you should already have if your doing hardcore mods IMO. On my old car that ran 100% meth I was sure to always watch the Knock. Because if the knock jumped up really high it would warn me and I would know most likely something is going on with the Meth Kit. Could monitor Timing also i believe.
07-27-2017, 08:33 PM | #18 |
Drives: Overkill Supercharged 2016 CamaroV6 Join Date: Mar 2016
here is a undershot of the install of the alky kit under my right wheel well. There are 2 lights on my dashboard one is a low level light indicator and another is a monitor light.
Hyperhawk - 2016 Camaro 2LT RS - First LGX in the 12's and 11's Current record holder 11.0@125
Follow me on Instagram https://www.instagram.com/hyperhawkcamaro/ Youtube https://www.youtube.com/channel/UCHR...-ilSpV3gMQnTuA Supercharged with Overkill Superchargers http://www.v6superchargers.com |
