10-22-2020, 04:04 PM | #1 |
Drives: 17 hyper blue 2SS M6 Join Date: Mar 2018
Coilover spring rates
I'm curious what spring rates you guys went with on your coilovers. Seems like 8k/12k is a standard rate. I'm curious if they worked well for you or if you had to make adjustments. I know every setup will be different, I'm just trying to see where people are at with them
I should say I'm more talking about on track use vs stance only or daily driver. |
10-22-2020, 04:08 PM | #2 |
what coilovers are we talking about?
10-22-2020, 04:19 PM | #3 |
I bought silvers neomax, not a whole lot of reviews on here, so kinda going in blind for our cars. I read a lot on other makes forums and I didn't read anything negative, other than being "cheap". I'm anxious to see how they hold up
10-22-2020, 04:33 PM | #4 |
aww i remember a thread about those before what springs are in them right now? swift , hyperco and what is the rate?
10-22-2020, 04:40 PM | #5 |
They're swift 8k in the front and 12k rear. I'm curious what other people have for spring rates, and how they feel about them. I most likely won't have mine installed before my next track day.
10-22-2020, 04:46 PM | #6 |
let me know what you think of them!
10-23-2020, 08:14 PM | #7 |
The Mechanic
Drives: 1SS M Join Date: Dec 2017
I did the first review on here of the silvers coilovers last year, so far no problem after a couple track days and some daily driving. I did swap the rears to 14k springs. A bit stiffer.
BTR 225 w/CNC Heads|JLT intake|Speed Engineering 1"7/8 long tube and mid pipe|LT2 manifold w/95mmTb|Self tuned w/HPtuners|Silvers 2Way coilovers|Hotchkis front sway|Advan AD08R|BMR solid cradle bushings|Recaro SR7| Work ZR10 19"
10-23-2020, 08:26 PM | #8 | |
Good to hear they're holding up for you. How's the adjustability of them? I got the default rates so we'll have to see how they feel. |
10-25-2020, 02:50 PM | #9 |
The Mechanic
They adjust well and noticable but at stock rates i do feel the rear doesnt dampen as much as id like. The rear i normally keep 4-2 clicks from full hard, and on track full hard on the rear. Front is somewhere in the middle. Im considering bumping up rates and valving a good amount.
