Old 07-18-2020, 09:28 PM   #1
MSU120
Drives: 2018 1SS 1LE
Boost gauge
I just installed a new mechanical boost gauge. It was zeroed until I took that “pin” out that it comes with. Now, it’s like 2 clicks to the negative when the car is off. When I start the car, it drops to about -20. Haven’t been able to drive it yet to check the boost reading. Is it supposed to be at zero when the car is off? Can you zero them?
Suggestions?
2018 SS 1LE—707rwhp, 615rwtq
2009 Pontiac G8 GT—605rwhp, SOLD
MSU120 is offline   Reply With Quote
Old 07-19-2020, 06:45 AM   #2
MSU120
Picture attached.
Old 07-19-2020, 07:05 AM   #3
thebanks06
thebanks06's Avatar
Drives: 2016 Chevy Camaro 2SS
Yea, then it will drop to negative when you crank. Hit 5th gear at a low speed and you should see it jump into boost
thebanks06 is offline   Reply With Quote
Old 07-19-2020, 07:07 AM   #4
MSU120
So it’s not supposed to be at zero when the car is off?
Old 07-20-2020, 04:01 AM   #5
thebanks06
thebanks06's Avatar
It does if I can recall correctly
Old 07-20-2020, 06:08 AM   #6
federal
federal's Avatar
Drives: 2019 ZL1
Logic would tell me, plus any other boost gauge I have seen and used, that it should be at zero when the car is off. Since it’s mechanical and digital, it will most likely read a few PSI below now when running.
2019 Camaro ZL1
federal is offline   Reply With Quote
Old 07-20-2020, 09:51 AM   #7
MSU120
Agreed....I think I have a bad gauge. I’ve emailed procharger, hopefully they’ll remedy it.
Old 07-21-2020, 07:24 AM   #8
MSU120
Procharger is sending a new gauge. Great customer service.
Old 07-23-2020, 04:47 PM   #9
MSU120
Replacement gauge installed. Its perfectly zeroed and works great.
Old 07-24-2020, 08:04 AM   #10
federal
federal's Avatar
Drives: 2019 ZL1
Good to hear, figured there was a problem. Never seen a gauge that wasn’t at zero when off.
2019 Camaro ZL1
