07-24-2018, 12:35 AM | #1 |
all it takes is cash
Drives: 2018 LS V6 1LE; E350 wagon; Model3 Join Date: Jan 2017
Alignment problem - LS/V6 1LE
I took my LS/V6 1LE to a local Firestone Autocare and got a lifetime alignment package. I gave them the supplemental owner's manual with Chevy's recommended specs, and they were able to reach & exceed the negative camber target for the rear axle, but could only get .8 & 1.0 degrees of negative camber on the front axle (negative 2.0 is the target). The technician showed real interest in the issue and we discussed what he tried, and he followed all the procedures listed in a detailed how-to post on this forum.
The only solution I can think of is to take the car to a Chevy dealer for and alignment and ask them to set the car to Chevy's recommended values in the owner's manual supplement. Then, if they can't get close to -2.0 on the front axle, my hope would be to have that investigated and fixed. Has anyone else had trouble getting the recommended front-axle camber? |
07-24-2018, 01:08 AM | #2 |
Drives: 2015 Camaro 1SS Join Date: Dec 2017
was only able to get -1.8 out of mine, and it wasnt easy.
07-25-2018, 04:22 AM | #3 |
Drives: 2018 1LS 1LE Join Date: Jun 2017
Yup I was also only able to get about -1.8 up front at an independent shop.
2018 Garnet Red 1LS 1LE V6 w/Tech
1100 - 07/26/2017 | 4300 - 09/15/2017 at rail yard 3000 - 08/16/2017 | 4200 - 09/18/2017 shipped! 3100 - 08/19/2017 TPW 09/11/2017 | 4800 - 09/20/2017 train journey done 3400 - 08/25/2017 | 5000 - 09/22/2017 at the dealer, and picked up! 4300 - 09/12/2017 Built! VIN available 4B00 - 09/14/2017 move to rail yard |
07-25-2018, 08:17 AM | #4 |
Drives: 2LT/1LE, HPCRX, F250(tow vehicle) Join Date: May 2016
I was able to get -2.0 on mine and -1.3 on the rear. He indicated to me that he had no problems at all getting the -2, there was also a lot more available for the rear but since I drive it every day we decided to stay at -1.3.
2017 2LS 1LE
'I feel that life is measured in achievement, not in years alone' Bruce McLaren |
07-25-2018, 11:53 AM | #5 |
Drives: 2018 1SS 1LE & 1973 Datsun 240Z Join Date: Sep 2015
My alignment guy said that after he backed off the nuts on the front strut bolts, he had to knock the bolts loose (like they were going to be driven out) with a hammer to get the strut to come free and move on the hub. I don't recall what the final alignment numbers were, but they were pretty close to the recommended track spec.
OP, care to provide a link to this "how to" post? |
07-25-2018, 01:19 PM | #6 | |
Drives: E46 S54 race car, 964C2 Join Date: Feb 2017
You shouldn't have to do the stut mod to acheive any camber value that the GM performance supplement recommends. If I were you, I'd tell my alignment guy this specifically: "the front camber adjustment bolt is splined, so before you try and adjust front camber, hammer the bolt out about 1/2 way to get past the splines" https://www.camaro6.com/forums/showthread.php?t=526353 |
07-25-2018, 06:18 PM | #7 | |
07-25-2018, 07:34 PM | #8 | |
Nigel |
07-26-2018, 09:55 PM | #9 |
Yes, so he said.
