03-12-2014, 08:50 PM | #29 |
http://www.camaro5.com/forums/showth...=271144&page=4
Several people are seeing higher numbers with the 1le. We also have one we have a procharger i1 on at 9 psi, custom grind headers, making 700 rwhp. |
03-12-2014, 08:53 PM | #30 | |
Drives: Black '13 SS 1LE Join Date: Mar 2013
He just laid it down, haters. Are you picking it up? |
03-12-2014, 09:02 PM | #31 |
Too much is never enough!
Drives: AGP TT SS [COTW] 4/20/15 Join Date: Feb 2014
i am aware that they make more power and we can all agree that the baseline numbers are on the high side...i think the real point here is you had great gains with some intake work and bolt ons. congrats
AGP TT kit, 54/57 Forged rotating assembly, Custom grind cam... Dual nozzle meth, ID850's, Livernois dual fuel pumps, ECS BAP, 25% UDP, 3 inch Magnaflow catback with X pipe, Mantic 9000 clutch, DSS 1000hp axles, DSS aluminum driveshaft, ZL1 rear end, solid subframe bushings, HE differential offset bushings, BMR Trailing arm, BMR toe rods, Lingenfelter LNC-2000,SJM Line Lock. 747 whp 714wtq
Build thread http://www.camaro5.com/forums/showth...55#post8107855 |
03-12-2014, 09:02 PM | #32 |
Just about every 1LE I have seen dyno'd, no matter where it was at, made over 380-400 range.
Its cool Mark, people will question things, all I know is that the car runs strong for what it is. |
03-12-2014, 09:13 PM | #33 | |
03-12-2014, 09:14 PM | #34 |
how the hell is that laying it down?? we were having a conversation...i am sure that i am not the only one with those thoughts...hell i worked in the same dyno shop off and on from 1996 to 2011 thats why all i cared about is the Gains...
my Clayton Eddy-current dyno was on the low side that does not mean my dyno was correct and his is not there are a lot of different varibles that effect HP as i know that my friend is aware of. i am clear that it is NOT Voodoo or magic for him to get 56 more HP that is an impressive gain but not far fetched forgive me if i took wind out of the OP's thread but as a former member if this industry i ask questions its what used to make me competitive in my town.
03-12-2014, 09:15 PM | #35 | |
03-12-2014, 09:26 PM | #36 |
Drives: Black '13 2SS/RS/1LE w/NPP/NAV Join Date: Oct 2012
My '13 1LE put down 368/365 bone stock @ 2K miles. I added Pfadt LT's with cats and a Vmaxx TB plus an ADM race intake. Jeremy Formato tuned it and it put down 432/422 @ 8K miles. Both on similar Dynojets.
Add a UDP and a ported TB and I believe those numbers. This thread tells me two things. I need to install my Fluidampr UDP and I need to get Rhino to get me one of his manifolds. Then I go back to see Jeremy. Good job Rhino... if you get a chance could you PM me some manifold pricing? Sent from my DROID RAZR HD using Tapatalk
My Build Thread... http://www.camaro5.com/forums/showthread.php?t=285054
03-12-2014, 09:38 PM | #37 | |
Drives: 2011camaro SS Join Date: Nov 2012
Op any plans on tracking it anytime soon? |
03-12-2014, 09:50 PM | #38 |
Drives: 2011 LS3 Join Date: Jan 2012
Its the airaid intake.
Vararam
Stainless Works Headers Vmax TB SLP loudmouth 2 Nightfury Cam Mike Norris CC Tuned by Southwest Speed |
03-12-2014, 09:51 PM | #39 |
Drives: 2010 2SS/RS Join Date: Jan 2013
It having the electric steering helps as well! Good numbers so far
03-12-2014, 10:02 PM | #40 |
Drives: 2013 SS Join Date: May 2013
Around here I'm seeing 2013s and up make 430-450rwhp LS3s bolt ons only so those numbers are right on the money. Heck a 2014 100% stock L99 dyno'd 362rwhp 366rwtq last week thats great numbers.
03-12-2014, 10:03 PM | #41 |
Electric Power steering swap jeff! if its possible. 11.20s all day!
03-12-2014, 10:10 PM | #42 |
