08-12-2019, 01:00 PM | #1 |
Dumb Ass Deluxe
Drives: A Tricked Out Mountain Bike Join Date: Jun 2019
L87 Block
Any difference(s) between the L87 truck short block and the LT1 short block?
(I'd think the cam is different at minimum) What about the heads? |
08-12-2019, 02:50 PM | #2 |
Drives: 2021 300 Join Date: Jan 2015
There are no spec's for the heads yet. But its an iron block motor not aluminium with lower compression designed for towing applications. Its rated and 401hp and 464tq.
08-12-2019, 03:22 PM | #3 |
Rayvan
Drives: 2018 1SS1LE, Silver Ice Metallic Join Date: Dec 2018
I think you mean L86. Same block as LT engines, but with lower compression and 420HP
08-12-2019, 06:58 PM | #4 |
Dumb Ass Deluxe
08-12-2019, 08:28 PM | #5 |
Drives: 2018 1ss, 2021 silverado HD Join Date: Jul 2017
I believe the lt1 and l86 share everything except intake manifold, exhaust manifold and tune. All internals are the same.
08-15-2019, 01:53 AM | #6 | |
Drives: 2016 Camaro 2SS A8 Join Date: Oct 2016
Parts sharing FTW! L86 specs https://help.summitracing.com/app/an...6-engine-specs LT1 specs https://help.summitracing.com/app/an...1-engine-specs |
08-15-2019, 08:59 AM | #7 | |
Dumb Ass Deluxe
The plot thickens.... |
08-15-2019, 05:08 PM | #8 | |||
Drives: 2019 Shock ZL1 Join Date: Jan 2007
The 6.2 L87 uses DFM (Dynamic Fuel Management) so all 8 cylinders can be "active" in terms of shutting down. 17 different patterns are possible with this, running on as low as 1 cylinder. DFM doesn't use a VLOM in the valley of the engine anymore like LT1 still uses. L87 has a flat traditional valley cover. There are now 8 individual oil control solenoids, one per cylinder to control DFM operation. Cylinder heads are the same part # LT1 to L87. L87 now uses an LS style water pump/water pump housing. LT1 has the L86 style water pump housing still. L87 and LT1 use different cams. Both are 11.5:1 compression ratio, 93 octane recommended/required, can run on 91 with reduced performance.
From Super Chevy mag, April 2002: "Most of the weekend Settlemeire was meeting and greeting and quickly became known as simply "The Camaro Dude" (note, even his initials are SS)."
