Old 05-29-2019, 10:53 AM   #15
69ss350
Drives: 69 Camaro SS
Originally Posted by VinnAY View Post
You need to just drop what you're thinking about and listen to those telling you to walk away from it.
Vinnay.....believe you me......I'm not touching that car with a 50 ft pole.
Just throwing it out there to see if anyone has replaced one of these aprons.
Sad......it WAS a nice car.
69ss350 is offline   Reply With Quote
Old 04-23-2020, 10:26 AM   #16
Irocz2818
Drives: 2018 camaro 1SS
Is there any updates if something like this has ever been fixed? Found mine with the same issues and it’s devastating
Irocz2818 is offline   Reply With Quote
Old 04-23-2020, 04:23 PM   #17
Deakins
Drives: 2017 2ss, m6
On the few chassis that I've seen set up for competition track use the strut towers were cut out and moved for geometry reasons. Take it for what it's worth but I would only deal with it if mine broke and I had no other option but to stay with it.
Deakins is offline   Reply With Quote
Old 04-23-2020, 05:29 PM   #18
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
It might not be that big of a deal if you can drill out some rivets and replace it, but a body shop would need to get it on a rack to check for any other damage, and if it gets on the carfax it will result in diminished value if it's considered structural damage.
Old 04-24-2020, 10:46 PM   #19
Dragon08
Dragon08's Avatar
Drives: 2020 1LE
There are not only rivets holding that to the motor compartment, but also structural adhesive. That is going to be a son of a gun to replace. To repair it.......you need to be a pretty skilled welder to handle cast aluminum..
Structurally, I'd have to say let the GM techs do it. I wonder what insurance would say about it.
Iroc, do you know what event took your tower out? Accident, curb, pothhole, shenanigans?
Dragon08 is offline   Reply With Quote
Old 05-01-2020, 05:58 PM   #20
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
This is what GM says in #19-NA-110 - Visible Cracks in Shock Tower Near Strut Top Mount
Some customers may comment on seeing cracks on the
shock tower, near the strut top mount. Some examples
are shown in the graphics.
Note: Be sure to inspect additional suspension
components and disassemble the tire/wheel
assembly to verify no other components are
damaged.
The cause of the condition may be a hard impact (such as
curb or pot hole) that drives a lot of energy up through the
strut tower casting, ultimately cracking it.
To repair this condition, the shock tower must be replaced.
Refer to Front Wheelhouse Panel Replacement (Partial)
or Front Wheelhouse Panel Replacement (Complete) in SI.
Note: Vehicles repaired for the conditions outlined in
this bulletin should not be considered warranty. Any
warranty claims submitted with these conditions may
be debited.
Old 07-20-2020, 06:42 PM   #21
snowwhiteZL1
Drives: 2018 ZL1 White
Does the insurance company should step up to the game?
snowwhiteZL1 is offline   Reply With Quote
Old 08-01-2020, 02:35 PM   #22
AlphaDream
Piston Slapper
AlphaDream's Avatar
Drives: Volt gen2, Colorado V6, soonCamaro
This is old now but I'd have asked the seller why he didn't have it repaired either under warranty or as an insurance claim. (thanks to carguy55 above on why it's not a warranty repair).
Obviously that used car is a hard pass. It could be repaired to be good as new, but that's not the most likely outcome. Now if it had a salvage title and you got it for a song then maybe it would be worth it. Maybe.
AlphaDream is offline   Reply With Quote
