12-08-2018, 06:13 AM | #71 |
Oh Oh it's Friday Night!
Drives: 2018 ZL1 1LE Nightfall Gray Join Date: Jan 2018
6,500 miles. Changes at 500, 1000, 1500, 3000, 6000. No cats so I run Mobil 0W40, the euro variety. Zero oil consumption. Very little in the catch can. I do wish the oil pressure was better in these engines. I monitor it on my aeroforce. Consistent but marginal at best I think.
Four that wanna own me Two that wanna stone me One says she's a friend of mine... Last edited by SJFGTO; 09-15-2020 at 05:57 AM. |
12-08-2018, 06:58 AM | #72 |
Drives: 2017 ZL1 Camaro Join Date: May 2018
Under normal spirited street driving I see no oil usage.
At a track day with 4-5 20 min sessions I use just under a quart. |
12-08-2018, 07:53 AM | #73 | |
Drives: 17 ZL1 Join Date: Mar 2017
2017 ZL1 Coupe M6, Red Hot
Mods; AFE Pro 5R CAI, Kong Ported Blower and Snout, NW 103 TB, Griptech 2.31 Upper, Kooks 2",JMS Voltage Booster, Flex Fuel, Mighty Mouse CC,Jannetty Racing Tune, 680 rwhp |
12-08-2018, 07:55 AM | #74 | |
Any thoughts on why that is?
12-08-2018, 09:47 AM | #75 |
I did not notice any difference in usage when I went catless and switched to 0W-40 euro from 5W-30. I have no tangible evidence but I suspect the oil usage might be less now because I certainly run the car harder modded, with but no appreciable difference. Oil usage was definitely less with Mobil 1 0W40 in my 2005 LS2 GTO (an engine that had consumption issues) than the 30 weight I originally ran. Regardless, just happy to report that I have not experienced any oil usage issues whatsoever in the ZE. 👍
Four that wanna own me Two that wanna stone me One says she's a friend of mine... |
09-14-2020, 01:21 PM | #76 |
Drives: 2018 ZL1 1LE Join Date: Jan 2020
My ZL1 seems to be using a TON of oil.... MOre than i am comfortable with for sure.... it was down TWO quarts after about 5,000 miles of use between 15k miles and 20k miles......
not reading on the dipstick after 5K miles to me, is unquestionably too much... I don't beat on my car. highway pulls, weekend driving and cruises.... so i'm hoping my service department can provide me with an oil log sheet and i'll show them myself....
2018 ZL1 1LE Summit White M6
"MOVN WA8" currently stock 2012 CTS-V Diamond White A6 Coupe "Becky" 1995 Z28 1LE 383" LT1 A3 N2O Drag Car 9.06@153 |
09-14-2020, 01:45 PM | #77 | |
Drives: 2018 ZLE Join Date: Feb 2018
09-14-2020, 02:12 PM | #78 |
Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
2 track days between changes and I didn’t see any consumption.
09-14-2020, 07:02 PM | #79 |
Yes, used one quart in first 2200 miles but it's too early to tell anything
'20 ZL1 1LE A10,
09-14-2020, 08:24 PM | #80 |
Drives: 2017 ZL1 A10 Summit White Join Date: Apr 2018
I use about 2 quarts in between oil changes but I think it's because I use the paddles to downshift everytime I drive. My prior car, ctsv would drink a little more. It is what it is I guess. I just check the dip stick often.
09-15-2020, 11:19 AM | #81 | |
Rayvan
Drives: 2018 1SS1LE, Silver Ice Metallic Join Date: Dec 2018
Just raise your hood once a month, and have a look. Oil level between the min/max marks....golden, if it's close to the low mark, add 1/2 qt. No big deal. Any dealer, I don't care who made the car will not even bat an eye, until you're consuming more than a qt. per 1000 miles. |
09-15-2020, 11:50 AM | #82 |
Drives: 2017 Chevrolet Camaro ZL1 M6 Join Date: Jul 2020
Zero oil usage at 24K miles.
09-15-2020, 03:45 PM | #83 |
1LE Convert
Drives: 2018 ZLE Join Date: Apr 2017
I only run Mobil 1 15W-50 and only drive my car to/from track and mechanic. I burn about half a quart per track day. Not sure if normal, but I haven't investigated it. Car seems to run fine.
2018 Camaro ZL1 1LE (Red Hot)
2002 BMW Spec E46 race car (Lizard Green) Previous cars: - 2018 Miata RF GT (Machine Gray/Auburn) - 2017 Camaro 1SS 1LE (Summit White) - 2008 BMW 135i (Montego Blue) - 1996 BMW 328i (Arctic Silver) |
09-15-2020, 04:23 PM | #84 | |
Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
I assume you track at Laguna Seca, what's your Laguna pipe solution? I saw a shop in Bay Area that has a nice slip on version. |
