03-31-2020, 04:08 PM | #1 |
Drives: 2019 Camaro 1ss 1LE Join Date: Feb 2020
best spark plug wires
I am needing to replace my factory wires cause im sure the car is starting to have a small miss in it. Car has headers and the factory wires are still on it. Was that way when I bought the car a month ago. Besides MSD are there any others that are better or as good for the around the same price as MSD wires?
03-31-2020, 04:24 PM | #2 |
Drives: SS 6 speed of course Join Date: Jan 2016
I used a combination of stock, stock with no steel sleeve + fiberglass insulation and 2 locations that I have ceramic angle boot wires, I think they are MSD wires. IMO there is NOTHING wrong with properly loomed stock wires.
03-31-2020, 04:30 PM | #3 |
Oh Oh it's Friday Night!
Drives: 2018 ZL1 1LE Nightfall Gray Join Date: Jan 2018
Stock wires with fiberglass sleeves. You’ll be fine.
Four that wanna own me Two that wanna stone me One says she's a friend of mine... |
03-31-2020, 04:33 PM | #4 |
mine still have to steel sleeves on them too. I would just leave the stock wires on there if I wasnt constantly hearing a small miss in it at idle and especially when you hit the gas in like 3rd gear at low rpm's where it puts a load to it. Really sounds like its missing then. Its a M6 by the way. Kind of supprised it hasnt thrown a check engine light doing it. Guess its not bad enough for that yet.
03-31-2020, 04:36 PM | #5 |
So removing the metal sleeves and putting the cloth ones on there will be better?
03-31-2020, 04:52 PM | #6 |
i have msd ones and high temp boots going on this weekend my shop told me to get the granatelli ones but they are like $300 plus compared to msd $90 so yea im good lol
03-31-2020, 05:45 PM | #7 |
If you need clearance and a bendable boot I think the msd is sufficient
03-31-2020, 06:08 PM | #8 |
By removing the sleeve you can bend the wire sooner, I made two brackets that bolt to the valve cover so the wires "pull away" from the header. I use bent ceramic boots in these two locations now. Either way works fine.
04-01-2020, 08:36 PM | #9 |
Drives: 2017 Camaro 2SS Join Date: Mar 2017
One of best spark plugs wires you can get are Granatelli. 0 ohms, but high price. Personally I don't think the price is worth the extra 4 HP. I love the idea of a thorough burn, but it's just too expensive.
04-02-2020, 09:02 AM | #10 |
I here that. How much are those Granatelli wires? Like 300 dollars? Compaired to like 85 for the MSD.
04-02-2020, 09:20 AM | #11 |
Stock wires have little to no resistance. CSP did a comparison and they had less resistance then MSD. None of them have enough resistance to cause any power loss. The granatelli are made very well and bend easy but they are expensive. I would probably just buy a new set of stock units and put sleeves around them.
2016 NFG 1SS A8
04-02-2020, 09:21 AM | #12 |
Drives: Chevy Camaro Join Date: Jul 2019
Stock wires are good. If you think you have a bad one ohm them out.
04-02-2020, 09:30 AM | #13 |
Drives: '16 2SS / '05 SRT10 Ram / '65 bu Join Date: Dec 2015
I've used the MSD wires, not impressed. I would look into Taylor. The boots swivel nicer and definitely invest in the metal sleeves for the added protection.
04-02-2020, 10:23 AM | #14 |
Drives: like an old lady Join Date: Jun 2012
i don’t like how short the msd wires are, but there’s a set on my car. other than that, they’re ok. being able to bend the boot is nice.
