08-07-2018, 06:15 PM | #1 |
The Mechanic
Drives: 1SS M Join Date: Dec 2017
18 SS Dyno before and after, stock vs FBO pump 93
It went to get a base run before the upgrades so if anyone was wondering here it is. The numbers did increase from 395 whpand climbed as we runs increased mostly due from the high temps from setting up the dyno, ratios and running the car etc. AFR leaned slightly from 11.9 to about 12.15 as we gained power.
404 whp 414 wtq m6 93pump 3000miles temp~90 degrees and humid FBO UPDATE!!! FBO UPDATE!!! Ok so im back some years later with the update. 21k on the car running 5w40 total energy 9000 oil JLT intake oiled blue filter freshly cleaned and oiled Speed engineering 1 7/8 long tubes with midpipes, stock muffler non npp Home ported stock tb Non ported C8 manifold Hptuners calibrated by myself Weather 70 degrees low humidity Final numbers 463 whp, 467 wtq uncorrected. If you want sae it removed about 4-5 hp and tq. We checked. Last edited by Joey Soul; 03-17-2021 at 01:24 PM. |
08-07-2018, 06:51 PM | #2 |
BAMF SS
A8 or m6?
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
08-07-2018, 07:32 PM | #3 |
Nice what spoiler is that
08-07-2018, 07:49 PM | #4 |
Drives: 2018 Audi TT RS Join Date: Jan 2014
You may want to contact this dyno operator and ask him for a SAE correction factor printout. Just for the sake of consistency if you use that same dyno later.
2018 Audi TT ▊RS
2.4X 0-60, 1.6X 60', 120+mph 1/8th, 4.XX 60-130, 150+mph traps on 255/35/18 R888R tires on the street (unprepped). 2019 Audi RS3 About as fast as the TT RS 2019 Camaro ZL1 1LE Sold 2018 Camaro SS 1LE Sold 2019 Corvette Z06 Sold 2021 Charger Hellcat Redeye Widebody Sold |
08-08-2018, 10:32 AM | #5 |
Drives: 2019 ZL-1 Join Date: Feb 2009
THe OEM calibration's are pretty dam good. 404 hp is 475 at crank.
2012 Yukon XL Denali w/ 6.2 AWD |
08-08-2018, 10:46 AM | #6 | |
BAMF SS
to the op: yeah you can basically throw that dyno chart out the window, since it is uncorrected. it's almost worthless.
08-08-2018, 10:48 AM | #7 |
Considering the DA when that run was made I’m pretty shocked how high the number is being std
08-08-2018, 10:53 AM | #8 |
Drives: All GM Performance Join Date: Jul 2011
Nice! What mods do you plan to do first?
08-08-2018, 10:39 PM | #9 | |
The Mechanic
Thats a bit dramatic. As hot as the day was ~90 degrees and high humidity im not sure how much SAE will drop the hp by calculating 77degrees and no humidity. |
08-08-2018, 10:42 PM | #10 |
The Mechanic
08-08-2018, 10:45 PM | #11 |
The Mechanic
08-09-2018, 12:58 AM | #12 | |
BAMF SS
And you also factor in barometric pressure and elevation...... and it can make a pretty substantial difference.... because you also have to factor in when your next dyno will be in The shop probably has the file saved.... you can just call them and they can send you the SAE or STD chart
08-09-2018, 07:09 AM | #13 |
Please return back or even just PM me w/ your results with the JLT. I had one on my 2014 and I loved it. The further along I get in my build, the more likely I am to switch to that.
2018 Audi TT ▊RS
08-09-2018, 08:07 AM | #14 |
HYPER SS
Drives: 2016 Supercharged 2SS Join Date: Feb 2014
How do you get the numbers? is there a chart you go by?
Ordered: 1/15/2016
2000 status 02/01/16 3000 status 02/29/16 3400 status 03/07/16 TPW of 03/14/16 4200 status 03/17/16 in transit! Delivered 03/23/16 2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points. | AWE touring - resinated catback with link pipes. |
