05-11-2021, 03:29 PM | #1 |
Drives: 2010 2SS LS3 and 1978 STROKER 383 Join Date: Feb 2018
Starting with the clutch
Can we somehow turn off the duty to stand on the clutch when we want to start the engine?
My life is a constant struggle with Camaro.
K&N CAI, Stainless Power longtubes, high flow cats, modified Ragazzon High Performance axle back, Soler Performance ported throttle body, Soler Performance throttle controller, RAM clutch adjuster, modified LS7 clutch kit, Tick Performance billet bearing support, Tick Performance remote bleeder, separate clutch reservoir, BMR trailing arms, BMR toe rods, Pedders Suspension cradle bushing inserts, Control Arm Bushings, Strut tower brace, oil catch can, Hurst T-handle shifter, 20mm wheel spacers, DBA brakes, QTP Cutouts, Dynosteve tune. |
05-11-2021, 04:27 PM | #2 |
My Road Rage is Legendary
Sounds like there's a story to go along with this question..
Every Time You Buckle Up In That Car, Tonight Might Be The Night That You Die.
05-11-2021, 04:32 PM | #3 | |
It don’t come easy.
Could be as simple as an inline switch but, more complicated going through the ECM.
05-11-2021, 04:40 PM | #4 |
Drives: 2015 2SS/RS 1LE Join Date: Nov 2020
Tuner can shut it off
SE 1 7/8 tubes and 3 inch X pipe, Vararam DRX, TSP stage 2 cam, Deatschwerks 50 lb injectors, Motion catch can, E85. More to come.
05-13-2021, 05:58 AM | #5 |
Hmm ... Not at all.
Rather, I don't want to stress the thrust bearings on the crankshaft during a cold start without enough oil. I can start all my cars in neutral, only the Camaro needs a clutch. I understand that it is a safety feature, but I have been driving with manuals for so long that I think I know when my gear is engaged and when it's not. In addition, in my work I drive with large trucks and it is strictly forbidden to start with a clutch. So Camaro deviates a bit from my habits
05-13-2021, 06:00 AM | #6 | |
But as far as 1LE_ROLL writes. Then the problem is solved
05-13-2021, 06:01 AM | #7 |
