02-23-2016, 09:09 PM | #1 |
Drives: '16 Summit White 2SS Join Date: Jul 2015
Interior lighting color change bug
The only problem I've received so far is that sometimes when I go to change the color of the interior lighting it says that "Color Selection Not Available in this Mode" but also doesn't show the other lighting modes. I have to restart my car to make it work again. Does anyone have this problem as well or know a fix to it?
Thanks!
Ordered: 2SS SW A8, Nav, Moonroof, NPP, Black 5-spoke rims, Black Bow Ties
1100 - 11/18 2000 - 12/11 3000 - 12/18 (TPW - 1/25) 4200 - 2/1 4800 - 2/9 5000 - 2/12 |
02-23-2016, 09:13 PM | #2 |
Drives: 18 Silverado 1500 Join Date: Dec 2015
We have this issue. Also, the drivers options disappear. Not sure why or if there's a fix.
09-22-2017, 08:30 PM | #3 |
Drives: 1SS Join Date: Sep 2017
Did you ever get this fixed? Having the same issue
09-23-2017, 06:17 AM | #4 |
Drives: Camaro Coupé 2.0T AT8 (EU version) Join Date: Mar 2016
If I'm not wrong, other people had this problem and solved it simply updating MyLink's firmware at the local dealership..
See you!!, Eos |
11-18-2017, 01:55 PM | #5 | |
Howdy! Pete here...
Drives: 2017 50th Anniv 2SS, A8, NPP, MRC Join Date: Jul 2009
Going with this theory, I experimented a bit and started "waking up" my car before starting it by unlocking the doors with the key fob, then locking it again. Then I either unlock again, get into the driver's seat, and start with button - - or I remote-start with the key fob (I have the A8). Ever since I started doing this (more than 3 months ago), the menus have been there 100% of the time! Hope this works for you...
PnCRedJwl2SS
2017 50th Anniversary Edition, A8, NPP, MRC, w/Sunroof and Glow-tie! ___________________________________________ ___________________________________________ Ordered from GM Delivered to dealership and home 9-16-16 This car is a beast! |
11-20-2017, 03:30 PM | #6 |
Drives: 2022 Wild Cherry SS Join Date: Aug 2012
I don't mean to hijack this thread, but is there a way to turn off the lights on the door panels and dash trim?
11-21-2017, 10:04 AM | #7 |
Drives: 2016 2SS, 2008 HHR ECTO-2H Join Date: Aug 2009
My car only has this issue when I use remote start.
As for retmil's question, on the interior lighting options screen there is an off button you can hit.
2016 Camaro 2SS. Hyper Blue, Ceramic White, Auto, MRC, and NPP.
1100 - 9/25 2000 - 9/28 3000 - 9/30 3100 - 10/27 3300 - 10/28 3400 - 10/29 TPW 11/09 3800 - 11/10 4300 - 11/24 4B00 - 11/25 4200 - 12/5 5000 - 12/7 6000 - 12/11 |
11-21-2017, 02:34 PM | #8 |
Drives: 2017 Camaro 2SS Join Date: Apr 2017
I had a problem with "Color Selection Not Available in this Mode", the fix in my case was turn the brightness button slightly down from full brightness and the color selection became available again. My problem may have been different from yours - I found the fix on this forum:
http://www.camaro6.com/forums/showth...ection+Mode%22 |
