08-15-2019, 12:03 PM | #15 | |
Petro-sexual
The '15 Z06 they performed the swap on was completely stock. It baselined at like 550-560 RWHP or something. Mike swapped the 2650 (there was a 2300 that was on it before, but that's not what you're asking about) with the 103 and GMPP CAI (the C7 kit, from what it looks like), tuned the car with only those changes, and put down about 700-RWHP at about 6500 and almost 730-RWHP at about 7000 where the car was running out of pump fuel. The car was on 91 octane. Seeing as how ZL1 and Z06 dyno within spitting distance of each other, it seems reasonable to think ZL1 would show similar numbers to those posted by Mike's Z06.
08-15-2019, 12:07 PM | #16 | |
Drives: 18 ZL1 A10 Join Date: Nov 2008
Nice gains for sure...
ZL1::J-E-T-S JETS JETS JETS |
08-15-2019, 12:57 PM | #17 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
What pulley is considered standard? I think i would change from that to a slight overdrive, but would have to make sure fueling wont be an issue. I would love to do a cam, but that is probably a 3-5k additional investment. Not sure the wife would be on board for that.
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
08-15-2019, 01:53 PM | #18 |
To my knowledge NW builds Katech TB and changes the blade to blue if I remember correctly. The only mods were the valve covers and fuel line.
Here is Billy's Zl1 which was the first install and I did mine the next week. We both ran 9's at Camaro Fest. His best was 9.82 and mine was 9.77 and we both had traction issues that weekend cause the track was greasy from the heat and DA. It was both cars first time out that weekend. I've since went 9.65 on 14 lbs of boost. Best mph was 145.
08-15-2019, 04:24 PM | #19 | |
Petro-sexual
I believe it might ship with a 90mm. If I understood Mike correctly, that is how they are going to try to certify the CARB-kit anyways. That is the pulley he ran on the Z06 which made the 700-plus RWHP completely stock, minus the blower, 103, CAI, and stated modifications (i.e. VCs, fuel line, intercooler lines, etc). FWIW - that was worth about 16-psi on his set-up, which would probably be similar in a stock ZL1 with a 103 and CAI, I bet.
08-15-2019, 04:50 PM | #20 |
Good job.
08-15-2019, 07:48 PM | #21 | |
08-16-2019, 10:59 AM | #22 |
Drives: Camaro ZL1 Join Date: Jan 2018
Is there any way to fit this supercharger with the standard intake system to keep the OEM look?
08-16-2019, 11:06 AM | #23 |
Petro-sexual
Because I've seen posts of installs with common bolt-on CAIs, which take the place of the OEM air cleaner box, it seems like it already has this feature. And, not that most people have to care about CARB-legal compliance, it (I believe) has to be compatible with the OEM box, so I think your concern is addressed, and it would be compatible.
08-16-2019, 12:24 PM | #24 |
Drives: Chevy Camaro Join Date: Jul 2019
Break a ring land yet?
08-16-2019, 12:54 PM | #25 |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
These are ZL1 guys, they're not likely to break a piston
Baby Blue
08-16-2019, 01:01 PM | #26 |
@viurniel
Drives: 19 ZLE A10, 15 2SS, 90 300ZXTT Join Date: May 2016
08-16-2019, 01:46 PM | #27 |
Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
08-16-2019, 02:12 PM | #28 | |
Thank you Al Oppenheiser!
https://www.camaro6.com/forums/showthread.php?t=550461 ...and yes I know it's very tuner dependent. |
