03-28-2020, 09:08 PM | #1 |
Drives: 2010 Camaro SS M6 Join Date: Apr 2016
Tire size question
I came across someone saying running to short of a tire will cause issues with stability control/traction control and ABS. Can someone shed a little light on this please? I’m lowered about 1 1/4 on 18 x 10 Forgestars square setup running 285/40’s all the way around. Is it something that can be adjusted in the tune??
03-28-2020, 09:31 PM | #2 |
It's only if you have a difference between front and rear. You are running square so no issues at all.
If you have ~1.4" tire height difference or greater you start having issues but you're good. |
03-28-2020, 09:44 PM | #3 |
03-28-2020, 10:08 PM | #4 |
10-19-2020, 01:51 PM | #5 |
Drives: 2014 Camaro Ss 1LE Join Date: Apr 2020
I am getting some new tires this week, and I will have about 1.2" difference between front and rear. Anyone know if this will be enough to give me any issues?
10-19-2020, 02:35 PM | #6 |
I am running 275/35/20 front and 315/35/20 rear and it is 1.2 difference and no issues. Been running them for about 6 months now. You should be fine.
10-19-2020, 03:07 PM | #7 |
Ok, awesome. I appreciate the help.
10-20-2020, 02:28 PM | #8 |
Most welcome ...
10-20-2020, 02:49 PM | #9 |
10-20-2020, 03:50 PM | #10 |
Drives: 2010 ss Join Date: Oct 2015
Thy say 3% difference between fronts and rears. Or about 1"
11-01-2020, 03:36 AM | #11 |
Drives: 15 Camaro 2SS M6 Join Date: Jan 2020
11-01-2020, 10:18 AM | #12 |
Yes sir, 20x10 front and 20x11 rears..M228's...
11-01-2020, 04:52 PM | #13 |
11-02-2020, 09:44 AM | #14 | |
