08-04-2018, 05:42 PM | #15 |
'It's an experiment'
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE Join Date: May 2014
I had axles popping out and a vibration...
Turned out to be diff bushings. Had to take the diff out to confirm: https://www.camaro5.com/forums/showp...&postcount=869 I had a lot of suspension mods when I found this... May be worth a check just to be sure. Tire sure can cause vibrations... sounds like you found the main culprit. -Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 |
08-07-2018, 10:11 AM | #16 | |
376 cubic inches of fun
There are a couple of things to consider. Did you launch shortly after getting the tires installed? The beads may have been wet. Did you lower the pressure at the drag strip? If you go too low, the tires will rotate on the rims. That's what bead locks are for. But for casual street night racing, just don't go ridiculously low. |
08-07-2018, 10:19 AM | #17 |
"Old School"
Drives: 2010 2SS L99 Join Date: Apr 2015
Drag radials wear like crazy, I would say it's just normal wear on them going out of balance. You would be much better off having two sets of wheels and tires. I always get my drag wheels balanced. I think they ride like shit when I compare them to my street wheels.
08-07-2018, 01:21 PM | #18 |
700RWHP-650TQ
Drives: 2011 Forged LS3 Supercharged/Cammed Join Date: Aug 2010
I don't drag the car.....these tires are for street use only.
View Build HERE>>>>>MY 2011 2SS/RS JOURNAL |
08-07-2018, 01:33 PM | #19 |
Drives: 2011 Camaro 2SS Join Date: May 2016
I'm having the same issue... I found that the trans mount on my vehicle is very soft for what I think it should be, when the car is in the air I can move the trans up and down about half an inch with minimal force, I've ordered a ZL1 mount that's "supposed" to be made out of a harder material, we'll see if that fixes my issue and ill work my way back from there.
2010 Camaro 2SS-Mods: Nightfury cam, CNC ported LS3 heads, CNC ported TB, Ported Intake, RX Catch Can, MGW Short Throw Shifter, Mantic 9000 Clutch, TSP 1 7/8 headers, catless NPP, BMR trailing arms, MMR Z/28 Reps 20" gloss black. SOLD
2011 Red Jewel Tintcoat 2SS-Mods: Edlebrock E Force S/C w/ 3" pulley swap,Texas Speed roller Boost Cam 227/235, 641"/649", 114 LSA, PRC Ported Heads, Ported TB,ARH 1 7/8 headers, McLeod RST twin disk 1000 hp clutch, ZL1 Fuel Pump, 620whp |
08-07-2018, 02:39 PM | #20 |
"Old School"
08-10-2018, 12:18 PM | #21 |
700RWHP-650TQ
I got 1 year out of them....2500 miles
