05-04-2018, 07:46 PM | #1 |
Drives: 2018 2ss 1le Join Date: Jan 2018
just speakers upgrade 2ss
are there replacement speakers for the bose system..
i mean like stock sizes and including bass only 6x9s that would be direct replacements i know this is not the best stereo but in a lot of ways its not that bad... i don't want to go amps and subs i just want to improve on the speakers and not mess with crossover points and stuff |
05-07-2018, 12:45 PM | #2 |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
From what I've read in this forum, unless you're willing to add amp(s) and a processor, etc....swapping speakers isn't likely to net you the sound improvement you'd expect.
05-07-2018, 04:52 PM | #3 |
even so.they should still improve system and the would be in place for the future if i go in that direction..
does any reputable company make replacements for the speakers |
05-08-2018, 10:59 AM | #4 |
Drives: 2016 Red Hot 2LT RS Vert Join Date: Apr 2012
There are adapters to make after market speakers fit in the factory locations. There are no direct drop in speakers. I would just go to your local audio shop and listen to a few good speakers and decide what to buy off that.
The front doors have 6x9 speakers but there are adapters to put 6.5" speakers in there as well. There are then 2 tweaters in the dash, 2 4" speakers in the rear side walls (can fit 6.5" speakers with adapters), and finally on some models with certain sound options you will have 2 6x9's in the rear deck. Your audio shop will have all of this information for you as well. I would definitely make sure you listen to some speakers before you buys as it is very subjective as to what sounds good to you.
05-08-2018, 02:15 PM | #5 |
i don't think that will work in this case...
as rear deck speakers are not full range and i think door speakers as well... i didn't see any replacements for the setup in the car. i figured some one here would have done this already... |
05-08-2018, 02:28 PM | #6 |
i see that they do make 2 ohm 6x9 subs
does any one have a breakdown of stock sizes and crossover points for bose system? |
05-08-2018, 03:25 PM | #7 |
Drives: 2017 ZL1 Vert - M6,SIM,CFW,NAV Join Date: Oct 2014
I have a complete service manual .... has a lot of stuff in it.. can get you a link to it.... 13K pages.
2018 2SS Vert - Hot Wheels - Indy 500 #30 2017 ZL1 Vert - M6 , SIM, CFW, NAV 2017 RS 1LT 2.0T Vert - A8, Garnet Red - SOLD :-( Added - IO6 - NAV, UHS - Enhanced Display, K4C - Wireless Charger, UV6 - Heads-Up Display - DIY 2011 CTS-V - Black / Black - SOLD. :-( 2013 ZL1 - Black / Black - SOLD. :-( 2010 2SS - Indy 500 Pace Car. - SOLD. :-( 2002 Z28 - Pewter / Black - SOLD. :-( |
05-08-2018, 04:29 PM | #8 |
yes thank you
PM me |
05-09-2018, 11:41 AM | #9 | |
Should you decide to tackle the rear deck 6x9's, do some reading here to make sure whatever you buy will fit. Getting the stock size in and out is already tight, and some aftermarket 6x9's have deep magnets. |
05-17-2018, 10:45 AM | #10 |
Drives: 2016 2SS, Red Hot, NPP, Nav, M6 Join Date: Jul 2016
Aren't the doors limited to bass frequencies only? A swap to a full range speaker for those is any benefit if the signal id bandwidth limited?
05-17-2018, 10:57 AM | #11 |
Drives: 2016 Camaro 2SS Join Date: Sep 2015
The 6x9 in the doors and rear deck...see 20-300hz....the dash speakers and rear side panel see 300-16,000hz
2016 Black 2SS A8 NPP Sunroof - Tinted Windows - Black Chrome Wheels - Custom Striping - ASC Sideskirts/Splitter - GM Lowering Kit - Complete Sound System - DD LED Sidemarkers
05-18-2018, 06:24 PM | #12 | |
I played test tones of varying frequency through the Bose system and this is what I got, 40-200 Hz: https://www.camaro6.com/forums/showthread.php?t=496885 |
05-20-2018, 09:48 AM | #13 |
my mistake...low end should be 40....upper end ranges anywhere from 200-300...either way...the point should be that the 6x9 should be considered bass only....nothing mid/full range...
05-23-2018, 01:43 PM | #14 |
Drives: 2017 Camaro 2SS 6MT Join Date: Aug 2006
I hate, I mean HATE, modern factory premium sound systems like our Bose. I'm old school, cut my teeth doing car fi installs in the 90s, where you had no DSPs and you could do a full custom system without breaking the bank or installing a ton of signal processors to reverse all the factory signal processing.
Not only are the rear deck speakers crossed over for bass only, the factory DSP rolls the bass off as you turn the volume louder to protect the speakers. The only way to get rid of that, and I hate it and I'm saving up for a big system install, is to use any of the signal summing processors out there that take all channels, mix them, and then give you full bandwidth output to all channels without roll off. Then you can cross over the channels as you prefer. I wish the Bose system was optional separately on the 2SS. Just give me the base 6 speaker system and let me upgrade to my own without dealing with factory DSP nannies. I hate it. |
