08-22-2017, 03:21 PM | #1 |
Drives: 2016 Camaro 1SS Join Date: Aug 2016
can I change between radio and media
Can I use the steering wheel controls to change between radio and media? My uconnect in my Ram will let me do this. How about Chevy mylink?
08-22-2017, 03:41 PM | #2 |
Drives: Summit White 2016 2SS Join Date: Jan 2015
Yes, swipe your finger from right to left over the music note on the mylink screen, it will then put your DIC into media mode, and then you can use the steering wheel control arrow to the right and move between all of the different types of media.
2015 1LE sold
2016 2SS sold |
08-22-2017, 03:43 PM | #3 |
Thank you I will give it a try.
04-15-2018, 06:37 PM | #4 |
Drives: 2017 2LT/RS & 2013 2LT/RS vert Join Date: May 2014
Must be a SS or above option? Doesn't work on my RS. Guess GM wants me to look away from road while I change inputs.
05-15-2018, 01:41 PM | #5 |
Drives: '21 Bronco OBX/'18 Jeep GC Altitude Join Date: Jul 2008
It works fine in my 2LT/RS, tried it at lunch today!
Order Placed: 04/30/22
Order Accepted: 10/18/22 TPW: 11/07/22 Built: 11/18/22 VIN received: 11/19/22 On a Train: 02/27/23 ETA: TBD 2023 Camaro 2SS Convertible/M6/Shadow Grey Metallic/Adrenaline Red Interior/Carbon Flash Wheels/NPP |
05-15-2018, 01:55 PM | #6 |
Drives: 2017 ZL1 Vert - M6,SIM,CFW,NAV Join Date: Oct 2014
Upper trim option.... RS 2LT. SS upper trim as well. I didn't have it in my 1LT until I added the Enhanced cluster and the IO6 HMI. Some wiring adjustments... and bingo.... G2G.
2018 2SS Vert - Hot Wheels - Indy 500 #30 2017 ZL1 Vert - M6 , SIM, CFW, NAV 2017 RS 1LT 2.0T Vert - A8, Garnet Red - SOLD :-( Added - IO6 - NAV, UHS - Enhanced Display, K4C - Wireless Charger, UV6 - Heads-Up Display - DIY 2011 CTS-V - Black / Black - SOLD. :-( 2013 ZL1 - Black / Black - SOLD. :-( 2010 2SS - Indy 500 Pace Car. - SOLD. :-( 2002 Z28 - Pewter / Black - SOLD. :-( |
05-15-2018, 02:12 PM | #7 |
Drives: 2017 Camaro RS Join Date: Mar 2017
05-15-2018, 02:14 PM | #8 |
I had the 8" already with IO5. The MOST wiring going from the HMI to the cluster had to be modified as it bypasses the cluster and goes to the AMP. Radio to AMP to HMI.... now it's Radio to AMP to Cluster to HMI.
I took care of that when I added the HUD.
05-15-2018, 04:42 PM | #9 |
Drives: 2016 Camaro 1LT Join Date: Apr 2016
Yeah, doesn't work if you only have the 7" screen
05-21-2018, 12:46 PM | #10 |
Need this option for it to work. "Convenience and Lighting Package"
05-22-2018, 08:15 AM | #11 |
Are you stating this for the IOB option with 7" radio? Because if you are referring to the I05/IO6 package, that is not correct. It can be done without the lighting package.
05-23-2018, 12:47 PM | #12 |
05-23-2018, 01:36 PM | #13 |
Lots of other things. Cluster programming and MOST wiring. Granted... I upgraded my IO5 now to IO6 and upgraded to the enhanced cluster
05-30-2018, 10:46 PM | #14 |
