07-18-2017, 02:50 PM | #43 |
Sure, why not?
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon Join Date: Mar 2015
Excellent thread!
07-21-2017, 08:26 PM | #44 |
Drives: 2017 ss Join Date: Nov 2016
so just to confirm, with the 2007–2014 CTS spare, ony a 5mm spacer is needed on the rear and no spacer at all up front..?
07-22-2017, 08:45 AM | #45 | |
The 5mm spacer is needed on the front. The spacer isn't required for the back, although it is used in the pictures I posted. |
03-18-2018, 11:08 AM | #46 |
03-18-2018, 12:43 PM | #47 | |
Sure, why not?
06-04-2018, 09:27 PM | #48 | |
Drives: 2016 2SS Join Date: Jan 2016
First you jack the rear and replace with the spare. Second you jack a front and replace with the flat rear. Third you rejack the rear and replace the spare with the front. Forth you rejack the front and replace the flat rear tire with the spare. Did it miss anything? |
06-04-2018, 10:30 PM | #49 |
Drives: 2017 Hyper Blue 1LE Join Date: Dec 2016
Yes, you may be able to jack the entire side up depending on the jack and the surface underneath.
06-04-2018, 10:31 PM | #50 |
06-04-2018, 11:27 PM | #51 | |
Drives: 2SS 1LE Join Date: Oct 2011
I think spare-tire anxiety is real. Sure, if you do a lot of long XC drives in areas where you can't get any help, then maybe you should rig something together, but for most people, even those that go XC occasionally, it probably makes a lot more sense to just have the roadside assistance with your insurance. Lastly, runflat tires are terrible. Which I switched them out on my BMW it was night and day. You don't want that crap on your performance car anyway.
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
06-05-2018, 12:13 AM | #52 | |
Drives: 2016 2SS, Summit White, A8, NPP Join Date: Apr 2013
Jack front replace front tire with spare Jack back and replace rear with front. Or do it your way. |
06-05-2018, 08:57 PM | #53 |
Drives: 2017 Camaro 2SS Nightfall Gray vert Join Date: Jan 2018
Or get the modern spare tire and just jack and replace whichever tire has the problem. I guess there are a bunch of options.
Magnuson Heartbeat SC - Tuned by JRE Racing 776whp/745wtq (12psi) 2018 Corvette Z06 vert- Black To be tuned by JRE Racing TBD performance |
06-06-2018, 08:48 AM | #54 | |
06-16-2018, 10:42 PM | #55 | |
06-16-2018, 10:56 PM | #56 | |
