09-05-2020, 06:37 PM | #1 |
Drives: 2018 White SS Join Date: Jul 2018
correct placement for 3/8 barb on LT2 intake?
Well I had a problem. As easy as the Lt2 intake is to install, car would not stay on. It stalled and wouldn't start. I put the lt1 intake back on and discovered my ls3 map extension from Michigan motorsports is crap. So before i put the lt2 intake back on I'd like to know if my placement of the barb for the brake booster is in the correct spot. thanks
2018 Chevrolet Camaro SS M6
2006 Corvette M6~ LS3 swapped,bolt ons tune 2013 Cadillac ATS 2.0T ~bolt ons tune 2007 Yukon Denali~Ly6 swapped w/LS3 cam tune |
09-05-2020, 06:50 PM | #2 |
Drives: 2019 Camaro SS Join Date: Jun 2019
Yup perfect
2019 Camaro 1SS A10 River Side Blue
Max effort tuning llc Rotofab dry, ported msd, nw 103mm Tb , speed engineering 2” headers, velossa tech,ati ud, aerospace front brakes, and flex fuel |
09-05-2020, 06:57 PM | #3 | |
Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
I may just completely cut off the connector housing on the MM connector just to try to get by for now. As for the connector you are showing that is for the brake booster connection? Did you have power brakes when you put on your LT2 manifold? The only other air hose that needs to be connected up is the PCV hose, which I found out as well is not a "direct bolt on" with the LT2 manifold, we need an extension hose as the LT2 plug barb stick up and there is no way you can make the stock one reach: Also if you have the rotofab (not sure how the stock air intake fits), with the throttle body pointed down at the angle it is, it makes the air tube really hard to fit up. I had to force mine on there at a weird angle. Also did everyone remove the sound insulator pad thing? I removed mine but not sure you have to or not, I would rather keep it if I can since I think it may help with sound and injector noise, although without it now it still sounds the same as it did I think. Sorry I didn't realize the question you were asking, yes it appears that the fitting is in the correct spot, although as long as your hose from the brake booster fits ok it seems like it wouldn't really matter? If its not running right and dying, maybe you just have a large vaccum leak and maybe did'nt get the manifold on right with all the bolts? although I think you would know that if it wasnt on and sealing. |
09-05-2020, 07:20 PM | #4 | |
Thanks for the reply. When i put my Lt2 intake on the car wouldn't idle long enough for me to move. Not to mention after 2 cranks it wouldn't start again. I got the michigan motorsports harness and mine has the right ends but its still crap. I thought it worked fine in my LS3 vette but then when I drove around my block i got a ses code. I'm sending it back. The PCV line is easy. Just used 3/8 fuel line and cut the ends. It fits perfectly. Same on the brake booster line. You are correct it takes some real maneuvering to get the Rotofab to work on the lt2. Since i have to wait for a new harness i put the stock intake back on and no issues
09-05-2020, 07:21 PM | #5 |
09-05-2020, 08:07 PM | #6 | |
09-05-2020, 09:07 PM | #7 |
https://www.amazon.com/Extension-Man...9-b698e0b800f6
This is the extension you need it’s the ict billet one. I made the thread on how to make it all work.
09-06-2020, 02:38 AM | #8 |
Drives: like an old lady Join Date: Jun 2012
i used the mm extension and it worked fine. the car had no issues starting up and driving like normal. wot was lazy for a few pulls but it's back to normal now. runs hard.
09-06-2020, 10:30 AM | #9 | |
If you don't have a good MAP connection the ECM will considered it failed and revert to sort of limp mode and you won't get full throttle opening. |
