09-13-2021, 09:12 AM | #1 |
Drives: 2017 Camaro SS Convertible Join Date: Jul 2019
Boost a pump needed?
Was going to order a boost a pump and install a lt4 lpfp when switching to lt4 injectors and lt4 hpfp. Is the boost a pump needed or can the voltage be adjusted during a tune now?
Found this article reason for questioning. https://forum.hptuners.com/showthrea...l-pump-Voltage |
09-13-2021, 12:37 PM | #2 |
The FSCM/CCM has been tuneable for some time now and it definitely helps extend the low side by changing the settings posted in that thread. You can try that first and then if the low side isn't holding pressure add the JMS later.
2016 NFG 1SS A8
09-13-2021, 01:20 PM | #3 |
Drives: 18 Z1E - 18 Raptor - 17 Jeep SRT Join Date: Dec 2019
If you need one, PM me. I have one I used for a couple of hundred miles and removed it.
09-13-2021, 07:03 PM | #4 |
