07-11-2021, 01:51 PM | #1 |
Drives: 2019 Camaro 2.0T RS/1LE Join Date: Jun 2021
CEL from Intake tube
The codes are P0113/P2227/P2229
I've tried unplugging and replugging the MAF sensor and checking all connections. I've driven it for 20 miles. CEL is still on. The radiator fan gets loud and now runs after engine is off for a couple minutes. Temp is fine. Pressure is fine. |
07-11-2021, 01:57 PM | #2 |
Drives: 2016 2SS Convertible Join Date: May 2012
Which intake tube did you install?
07-11-2021, 02:05 PM | #3 |
Drives: 2017 Camaro SS, 2011 Corvette GS Join Date: Feb 2019
Check all of the clamps and connections of the intake. You likely have a leak somewhere.
07-11-2021, 02:28 PM | #4 |
Turned off/on battery. Now just get p2227 code. The fan noise when away. Seems to run fine.
07-11-2021, 02:31 PM | #5 |
