09-17-2021, 08:18 AM | #71 | |
I see the feedback when shops freak out because they don't recognize aftermarket parts or what they do. So it is much harder to find someone willing or knowledgeable to work on your car when you have what could be called a Unique system. So the KISS method has a lot of Merit. Ted.
www.jannettyracing.com
09-19-2021, 11:58 AM | #72 |
Drives: 2015 C7 Z06 M7 Join Date: Dec 2012
Thanks, we'll soon release of our R1740 LT4 SC plate system that will fit otherwise stock vehicles (stock valve covers and stock coil location). This should work with LT1/LT4 - Whipple, Maggie 2300, Stock 1740 Supercharger, and NA intake manifolds.
09-19-2021, 02:18 PM | #73 |
Old badass
Drives: 14GMC 2.9 16GMC Turbos 2020Silv.6.2 Join Date: Mar 2020
Thanks, I do have a 2.9 on my DD as well
09-19-2021, 05:01 PM | #74 |
Drives: HBM ZLE Join Date: Aug 2017
Will it require cutting of the hood like the ones for the Magnusson? On a ZL1
09-19-2021, 06:36 PM | #75 | |
Dyno Show Queen LOL
This way you can run lid spacers and injector spacer. Or even FI chiller spacers w toohighpsi spacers and a lid spacer.
09-21-2021, 01:24 AM | #76 |
Don't know yet, as we've only test fitted Maggie's with the plates so far, but we'll have that information soon.
09-21-2021, 04:20 AM | #77 |
Dyno Show Queen LOL
They work w an oem blower w different valve covers.
https://www.instagram.com/p/CQcmMySB...dium=copy_link
10-02-2021, 11:07 AM | #78 |
Old badass
So I've about talked myself into the 1k combo from XDI that includes the big bore and +30's for a very good price. Add a hellcat in tank and DSX low side and should be good with a hi lobe cam on E something.
My 1st question is how high 38,40,42? Also, I'm tempted to go with more cu in for low street boost like 14 but with a boost controller so I can turn it up. 2nd question more cu in requires more fuel so should I stay away from a 427 or a 416? Remember 5200 lbs 4wd race weight with twins so I'd like the bigger engine if feasible and there is not THAT much difference in prices from 6.2 to 416. 427 about 2k more. |
10-02-2021, 12:25 PM | #79 |
If you get a big bore pump then you might as well get a 42% lobe to make use of it. Stock cubes is all you need with boost. 416 or 427ci engines have yet to prove they run any faster with boost. You end up with more low end torque which I don't think stock cube LT engines lack any in that department.
2016 NFG 1SS A8
10-02-2021, 02:39 PM | #80 |
Old badass
King I was just thinking for the street out of boost it may be more fun to drive with more low end because that would be it's main purpose anyway. A weekend driver on the prowl. I mainly just cruise around and don't beat on my stuff unless there is a decent challenge. Would it have enough fuel with more cubes? I'm not spending 11-12k on fueling lol.
10-02-2021, 08:57 PM | #81 |
Don't get me wrong there is nothing wrong with going bigger cubes. You can run less boost, make similar power, and have a fatter torque curve which I could see being a bonus for a heavy truck or suv.
But this video here kind of supports what I was trying to say. Note the Camaro owner purchased the LT5 rotating assembly from the ZR1 owner for his build, then beats the ZR1 that went with a 416. This is ShizzySupra's 6th gen. https://youtu.be/mbjAae-z1Og
2016 NFG 1SS A8
10-02-2021, 09:38 PM | #82 | |
10-03-2021, 11:25 AM | #83 |
Old badass
Thanks guys, enjoyed that vid lol. Point made! Back to question 2 though would I even have enough fuel for a stroker anyway since CR port is mia. I'm having the same supply issues in my AC business so I get it. I have definitely entertained just doing drop-ins on the existing 5.3 but it gives up a ton on head flow so I'd need probably 20lbs to run hard and then there's the lack of out of boost torque for my plus size girl. Sure would be less $$ but I'm prepared to spend. Just not frivolously. Heck I could buy a C5 for not much more that a big DI fuel system.
10-03-2021, 12:22 PM | #84 |
Drives: 18 Z1E - 18 Raptor - 17 Jeep SRT Join Date: Dec 2019
I've been working on my setup for about 6 months now due to supply issues, but I'm almost done
Dw400 in stock tank feeding surge tank 1.5 gallon surge tank in trunk with 3 dw400 pumps Stock tank and 1 surge pump run full time 2 surge pumps kick on under boost -10an line all the way to stock high pressure pump +32 cam -10 line to xdi belt driven pump +30 injectors -8an line from regulator back to the surge tank Should be good for full e85 lol! |
