Old 06-16-2017, 07:37 PM   #1
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
GM RED thread sealant part number?
GM uses a RED thread sealant on the trannys and rears.
Its not Loctite.
Anyone know the part number?
-Bobby
ZL1::J-E-T-S JETS JETS JETS
bobby35ny is offline   Reply With Quote
Old 06-16-2017, 09:08 PM   #2
PinHead
Drives: Duramax
p/n 10953491
http://www.acdelcochemicalcatalogue....search=Sealant
PinHead is offline   Reply With Quote
Old 06-18-2017, 08:58 AM   #3
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
Smile
Originally Posted by PinHead View Post
Ordered!
Thank you!!
Old 06-18-2017, 09:52 AM   #4
PinHead
Drives: Duramax
Glad to help.
I'd have some solvent(alcohol, acetone etc) on hand to clean up any excess.
Old 07-04-2017, 09:30 PM   #5
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
Per the service manual, the part number is 12346004 (used on the transmission plugs/sensors). I do not see sealant referenced on the SS differential fill or drain plugs, since I believe there's a nylon type seal for those.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
Old 07-06-2017, 09:55 PM   #6
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
I hear ya about the service manual, but that stuff is WHITE in color.
Wanted the red that they used...
Old 07-07-2017, 05:47 AM   #7
vtirocz
vtirocz's Avatar
12346004 is white?
Old 08-04-2021, 10:20 PM   #8
UnknownJinX
UnknownJinX's Avatar
Drives: 19 Chevrolet Camaro 2SS 1LE Shock
Super old thread, I know, but just in case someone got curious as I did...
That red stuff they use on the OEM plugs, from my Google-fu, seems to be a product called Vibraseal, or Loctite 516. Look up "Loctite 516" and you will see pictures of bolts with that same red stuff you see on the threads of the plugs. It looks to be extremely difficult to get it outside of a commercial wholesale setting, and pretty expensive, too. It makes sense for OEM to use it because they can use the sealant on a ton of parts that may sit for months or years before they are sold and installed.
For mechanics and DIYers, Permatex 592 is what you use(which is the same stuff as GM part number 12346004 mentioned above) on these plugs. It's white, but who cares, unless you feel like shelling out $100+ just for the right colour sealant.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock
GM Performance Intake and that's it, because driver mods before car mods
Past:
2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold)
2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled)
UnknownJinX is offline   Reply With Quote
