05-10-2016, 05:17 PM | #1 |
Drives: 2013 2SS/RS VR 1LE Join Date: Jan 2013
ADM FPCM vs Stock
I have a 2013 Camaro SS 1LE. Which already has the ZL1 fuel pump in it but its not set up like a ZL1's is.
I was looking to get ADM's FPCM but then there was talk on a thread about having to tune the fuel pump and they were using the ZL1's tables. What is the difference of an ADM FPCM and just changing my FPCM over to a stock ZL1's FPCM??
BC Racing coil-overs, 32ml rear sway bar, Solid cradle bushing kit, Steel jacket radius rod bushes, JPSS caster bolt, Bo White TB, Granitelli HP coils, Apex Catchcan, Vortech V7 Ysi Supercharger, LSX B-15 engine, custom spec cam, and other stuff.
05-10-2016, 05:28 PM | #2 |
From experience, if you buy a factory ZL1 FPCM, it does not come programmed, therefore the car WILL NOT start. The module must be programmed, independent of the ECM. Unfortunately, to get the full benefit of the ZL1 pump: a) you'd either have to have access to a Tech2; b) pay the dealer to flash the new ZL1 module; c) or just buy ADM's FPCM. I went the last route myself....
-Scott |
05-10-2016, 06:48 PM | #3 |
Just got back from the dealer. Ran down to see if my idea was true. Seems most of GM's FPCM are the same part number.
Tomorrow they will program my module to the ZL1 settings.
05-10-2016, 06:51 PM | #4 |
Drives: 2013 Camaro SS 1LE Join Date: Oct 2014
I used the adm unit. The tune will need to be changed as well.
05-25-2016, 11:42 PM | #5 |
Im curious about the out on of this effort to modify the FPCM. You have any detailed info at this point?
05-26-2016, 12:37 AM | #6 |
Too much is never enough!
Drives: AGP TT SS [COTW] 4/20/15 Join Date: Feb 2014
Your tune will still need to be changed, regardless of which FPCM you decide to buy.
AGP TT kit, 54/57 Forged rotating assembly, Custom grind cam... Dual nozzle meth, ID850's, Livernois dual fuel pumps, ECS BAP, 25% UDP, 3 inch Magnaflow catback with X pipe, Mantic 9000 clutch, DSS 1000hp axles, DSS aluminum driveshaft, ZL1 rear end, solid subframe bushings, HE differential offset bushings, BMR Trailing arm, BMR toe rods, Lingenfelter LNC-2000,SJM Line Lock. 747 whp 714wtq
Build thread http://www.camaro5.com/forums/showth...55#post8107855 |
06-13-2016, 12:36 AM | #7 | |
The car goes for tuning next weekend so we'll see. I checked the part#s at Chevy ad its the same FPCM, in every Chevy car. They just reprogram it for what they need. I went in, off warranty and asked the shop foreman if they could write mine (PCM) like 2013 ZL1. He checked my data and said why not. Left the car there and came back to two thumbs up. So next step is getting the whole computer up to snuff. Big tune in a week.
06-13-2016, 05:38 AM | #8 |
There have a been a lot of rumors about this. I think conformation will still be when you see the fuel options available for tuning and get the final data. Thanks for the update.
06-13-2016, 07:26 PM | #9 |
All good so far, car is running. Dyno tune next week. right Bernie??!!
06-13-2016, 07:58 PM | #10 | |
Drives: 2010 Camaro SS AT6 (L99) Join Date: May 2016
I was wondering about this and i'm not showing the same part numbers for FPCM. If I am researching correctly the FPCM for a 2012 Chevy Camaro ZL1 is 22872266. The P/N for the 2012 Camaro SS is 2086726. The P/N for a 2012 Camaro LT is 20867261. Am I doing the research wrong? Thanks Mike |
06-13-2016, 08:06 PM | #11 |
Drives: 2010 Camaro SS Join Date: Dec 2006
The FPCM's can be programmed. That's basically what ADM does. You may get the smoke screen tongue lashing from the preferred vendors and their henchmen on this thread eventually. But there is no real majic in reprogramming the FPCM. That being said...the FPCM unit costs $100ish, need to be programmed, and ADM is selling them for $225 if I remember right. It's not like it's a rip off. Pretty well priced in the grand scheme of things. And straight up works.
If you want to find your way around this....yes, it can be done. You might save $50-$100 at best. Not knocking it. To each their own. But the ADM deal works and is a great option to just buy from a trusted vendor and be done. My 2 cents... |
06-13-2016, 08:22 PM | #12 |
...not a marine biologist
Drives: 2012 Camaro RY SS LS3 Join Date: Mar 2013
ADM FPCM and call it a day. Spending free time on something like this isnt worth it. Use it for something else like... oh forget it. I see you are cammed and blown according to your signature!
Forged 416 stroker Turbocharged with Huron Speed with Cam Motion custom grind,Tuned by Vengeance, 8psi, 25% PowerBond UDP, Ported TB, shaved heads, LS9 gaskets, chromoly pushrods, BT trunnions & dual valve springs, IWIS, Might Mouse CC, SJM Line Lock,, MSD 2-Step, ZL1 Rear End, ZL1 spoiler, Strut Brace, ARP bolts, Skip shift elim, A-Pillar Gauges, FR Style 41 20X10, 3 inch exhaust, blackouts, Lowered, Custom badges, Hines vents,RPI fender vents, Technostalgia Tail Lights, Metra Kit, Pioneer stereo, Morimoto RGB Halos,
"The Great Awakening" on gab.com |
06-13-2016, 11:00 PM | #13 |
Drives: 2014 1SS/RS, 2018 Silverado CC Join Date: Apr 2014
So is the ADM FPCM plug and play. Just swap them out and that's it, nothing else needed?
AGP 57/57 turbos and Dual Pump System, NA Cam, McLeod RXT clutch, MGW shifter, ZL1 Rear End, BMR Trailing Arms/Toe Rods, Pegasus Solid Cradle Bushings 10.7 @140mph M6
06-14-2016, 07:57 AM | #14 |
WILD CANADIAN HEARTBEAT
Drives: 2014 2SS 1LE RS, 2014 ZL1& 2024 ZL1 Join Date: Sep 2014
Definitely following this thread Mike. Glad you are doing this before me. Interested in the real outcome.
700/633 91Octane Street Tune=750/670 VP109 Race Tune TVS2300 Heartbeat SC,ADM Dual Fuel Pumps/ Module, BRM lowered 1", performance rotors, hawks pads, SS Braided lines, GT-14cam, 78mm pulley, AR LT Headers, Cat Deletes, Borla S catback, tinted, 1/LE emblems, 65lb Injectors, Elite catch can,dual valve springs, titanium retainers, super conductor wires and insulators, Robo Fab CAI, Oversize intercooler reservoir, Oracle ghost side markers, Black out Bowties & SS,ZL1 splash guards, Michelin PSS. Built and tuned by Davenport Motorsports (WILD1LE)
