12-18-2017, 05:26 PM | #15 |
Retired from Car mfrs....
Success!
Taking two ideas from above, I used the frame puck and jacked up as high as it would go on each side, jammed the ramp underneath each wheel and lowered it back down. That put enough weight on it that it wouldn’t skid..… Oil changed… Success… Thank you guys…esp Mark..... By the way, found these for the harbor freight jacks: https://www.autobodytoolmart.com/cha...s-p-11539.aspx
12-18-2017, 05:29 PM | #16 |
Drives: 2017 2lt rs Join Date: May 2017
12-18-2017, 06:25 PM | #17 |
Drives: 2021 Crush ZL1 1LE Join Date: Oct 2009
When I used my old wood ramps, sliding was an issue. I cut up some old, cheap floor mats and stapled them to the pointy underside of the ramps. Car weight was on the mats first so the ramps didn't slide.
2021 Crush ZL1 1LE |
12-18-2017, 07:18 PM | #18 |
Drives: 2016 2SS Convertible Join Date: May 2012
12-18-2017, 07:25 PM | #19 |
Thank you Al Oppenheiser!
+1. This, or a carpet remnant, double wall corrugated box, piece of plywood, etc...
12-18-2017, 09:35 PM | #20 |
Drives: '17 2SS 50th Join Date: Sep 2016
I've had the same problem with my garage at my previous place.
The ramp kept slipping forward when I tried to drive up. Returned it right away and used a low profile jack since. As one member mentioned, cut a lumber and wedge it against the wall and the ramp so that it doesn't slip forward. Good luck!
'17 2SS 50th Anniversary | M6 | MRC | NPP | Nav | Sunroof | Black bowtie | GM dark tail
12-18-2017, 09:40 PM | #21 | |
To each his own, all I do on my car underneath is oil changes. If I can use a ramp versus a jackstand and a jack, I will. I own 2 low profile Jacks and stands when the wheels need to come off. But I don’t like screwing up with the frame crimps etc. if I don’t have to. |
12-19-2017, 10:16 AM | #22 |
Totally agree.
If I can drive up on to a ramp, I would much rather do that than jacking up.
Thread Tools | |
