03-14-2021, 08:21 PM | #1 |
Drives: 2019 Camaro SS Join Date: Sep 2020
2019 Camaro SS Totaled or Not
First accident and was wondering if my car is totaled. Was blindsided by pickup truck while turning and airbag deployed.
03-14-2021, 08:41 PM | #2 |
Drives: 2021 LT1 6spd Join Date: Nov 2020
Airbags usually means totaled, have you called insurance yet?
Current: 2021 LT1 Camaro, 6spd, Crush, Corsa NPP, GMPP CAI, Soler Performance Throttle controller
Previous: 1997 V6 Camaro, 5spd, Black |
03-14-2021, 08:43 PM | #3 |
I have they coming to pick it up tomorrow
03-14-2021, 08:43 PM | #4 |
Drives: '17 Camaro 2SS & '99 Camaro Z28 Join Date: Feb 2014
R.I.P
and TBH I would 'want' them to total it. Definitely wouldn't want it repaired. |
03-14-2021, 08:48 PM | #5 |
Me to. The resale value is definitely going to be low
03-14-2021, 08:49 PM | #6 |
03-14-2021, 08:53 PM | #7 |
Wasn't painful in the moment but about two days later was a different story
03-14-2021, 09:18 PM | #8 |
Drives: 2002 z28, 2018 2ss 1LE Join Date: Sep 2012
How many airbags went off , they’re each pretty expensive
03-14-2021, 09:25 PM | #9 | |
Drives: 2016 Camaro 2SS Join Date: Sep 2020
Not all the time. Depends on how new the car is. I've seen several times where cars have had airbags go off but not totaled and fixed. I've even seen Camaros on car dealer lots on their carfax saying airbags deployed in collision and towed and being sold. In my personal opinion based on that damage I would fight to have it totaled if they want to repair it. Damage to the Chassis as well and I wouldn't want that car and all that collision data on my carfax when I go to trade it in. It's like herpes with damage like that. I know with my SS if it had damage that bad I would fight to have it totaled. Who knows how it will be after being fixed as well. I wouldn't want to be stuck with that car and not being able to get good value when trying to unload it. My personal opinion but I wouldn't want my car if it had that bad of a collision. I'd be fuming if it wasn't totaled. |
03-14-2021, 10:24 PM | #10 |
All but the one in the steering wheel.
03-14-2021, 10:28 PM | #11 |
Depending on your mileage that’s gonna be close with all those airbags going off.
03-14-2021, 10:31 PM | #12 |
Drives: 2016 2SS Convertible Join Date: Dec 2019
That body between the front and rear subframes has to be tweaked beyond what any repair can fix. Look at the right side door gaps, if they’re off it’s totally bent through the middle and should be totaled.
Glad you’re okay besides some latent aches. Don’t let those go either and don’t settle anything until you’re sure you don’t have long term effects.
Hyper Blue/Ash Gray A8 Magnetic Ride Control Dual Mode Exhaust 2019+ version Split Spoke Silver Wheels Navigation Silver Rally Stripes |
03-14-2021, 11:15 PM | #13 |
Drives: 2018 camaro 2LT Join Date: Nov 2020
normally. if it cost more to repair the damages than the resale value of the car, then its totaled. check with your insurance. anyway, glad your okay
03-15-2021, 03:31 AM | #14 |
Drives: 2018 Camaro SS Join Date: Jan 2021
Mileage? Specs (2ss, 1le, mag ride)? Depends on value of car. Previous questions will determine. If frame is damaged will be totalled. If damage just panels and air bags the will probably fix. Say your car is worth 35k, the could spend 34k to fix it if they wanted. My guess is it will need over 26k in damage to total it. Not likely w/o frame damage. Was the other motorist insured and ticketed? If so Google “diminished value” and your state. Some states require and others have case law where you can get settlement for “diminished value” of car. If other guys fault they are required to make you whole. In some states that means not only fixing but paying out because your car will be worth less with that bad of an accident on your Car fax. Sent from my iPhone using Tapatalk |
