09-09-2015, 09:19 AM | #1 |
雪の玉
Drives: '22 Z71 RST Silverado Join Date: Feb 2011
plasti-dip'd the chrome on RS bumper
Finally plasti-dipped the chrome leading edge on my front fascia . The trick is to apply a really good coating and pull the tape off while wet, trick I got from 15cammedSS in one of his posts . Thanks bunches . Only thing left is the rear bowtie.
09-09-2015, 10:28 AM | #2 |
The BBOMG fill-in husband
Drives: 2015 2SS/RS 1LE AKA V1LE Join Date: Aug 2010
Looks good!!! I'm on the fence with mine, you don't really see it on the white
UPSTATE C5 MEMBER
09-09-2015, 10:49 AM | #3 |
Drives: 2014 SS1-1le Crystal red metallic Join Date: May 2015
I did the same . Looks a lot better
09-09-2015, 11:22 AM | #4 |
Drives: Camaro 1LE Join Date: Mar 2015
Looks great!
I took mine out completely. I hate that chrome strip! |
09-09-2015, 11:34 AM | #5 |
Drives: 2000 Camaro SS Join Date: Feb 2010
Much better.
09-09-2015, 01:42 PM | #6 |
Drives: 16' RedHot2 6MT SS Join Date: Aug 2015
09-09-2015, 02:16 PM | #7 |
Drives: 2015 1SS / RS NPP Join Date: Apr 2015
Would love to see some pics myself, as doing something about it is on my list of cosmetic mods I'm contemplating. I've gone so far as to research just replacing the fascia with that of a non-RS SS.
09-09-2015, 07:01 PM | #8 |
Drives: 2015 Camaro SS/1LE Join Date: May 2015
Looks great! So, was the technique the other member suggested just peeling masking tape while wet? Or, more? Or, can you point me to his thread?
Thanks!
2015 2SS/1LE/RECARO/NPP/RS/NAV
09-10-2015, 08:00 AM | #9 |
雪の玉
Yes Steve. Make sure you have complete coverage before you peel the tape off, and peel it carefully. It's a bit tricky, you have to work fast but careful at the same time. I was worried about getting it off while still wet and probably rushed the spraying, that when I peeled the tape off, I had found several tiny spots on top along the bumper of both headlight sections that didn't get covered. so I had to wait for it to dry and re-mask and hit the spots again. Luckily the center section came out perfect, so touching up the smaller headlight areas didn't take too long to cover back up and re-spray them.
09-10-2015, 08:19 AM | #10 |
Appreciate the write up nancygrl.
09-10-2015, 11:11 AM | #11 | |
09-10-2015, 12:26 PM | #12 | |
Drives: 2015 2SS....white Join Date: May 2015
2015 Summit White 2SS/RS with NPP.... Roto-Fab intake....Phastek lowering springs....BMR strut brace....custom cut blower cam and tune by Matt Sorian.....@MSTuning...BTR valve train....stainless power longtubes with HF cats....Phastek supplied
09-10-2015, 01:48 PM | #13 |
What have you created?! Thanks for enlightening nancygrl who then enlightened me!
09-10-2015, 02:39 PM | #14 |
