02-04-2013, 03:50 PM | #29 |
Drives: 2015 Z/28 #533 Join Date: Jul 2012
It all depends... Sometimes I hit all the gears, sometimes I start in second, sometimes I go from 3-6. I just love being able to row my own gears.
02-04-2013, 04:11 PM | #30 |
I usually will skip 5th. I only use it when I want to be economical but the flow of traffic makes 6th to much.
Mods: BBK Intake, BBK LT's and High Flow Cats, Corsa Cat-back exhaust, Hurst short throw shifter, SLP skip-shift eliminator. 7/1/09 Placed order for IOM/IO int/ SS/RS 6M 9/26/09 Took delivery! |
02-04-2013, 04:41 PM | #31 |
Guest
Drives: bbbbbb Join Date: Dec 2012
You guys paid for 6 gears you should be using them all. No sense in having 5 worn out gears and one good one left in the tranny! JK! LOL!
02-04-2013, 05:09 PM | #32 |
Go Gators!
Drives: Camaro Jeep Abarth 944 325i Join Date: Jan 2013
Since I have a V6 I don't skip, but I remember reading in the owner's manual that V8 models have a skip feature built in. Maybe if I had a V8 I might, but it feels just right rowing through each and every gear on the V6.
02-04-2013, 06:10 PM | #33 |
Drives: 2013 SS Join Date: Nov 2012
I don't skip gears, that seems un natural
02-04-2013, 06:19 PM | #34 |
Drives: '13 ZL1 IOM M6 Join Date: Nov 2012
Situational...depending on road conditions and the traction you want to translate from your rightfoot/wheel/road
Butt...if you want to pass that car in front of you on the roadcourse...match the RPM w/speed entering the turn to utilize your powerband and zip by him |
02-04-2013, 06:50 PM | #35 |
Drives: 2014 RRM ZL1 M6 Join Date: Jul 2011
I skip gears all the time. I'll go 0-42ish in 1-2 and skip to 5th if I'm the first car at a stoplight. I skip 4th quite a bit, because I'll shit into 3rd around 22-23 mph and get up to 40+ from there and skip to 5th.
02-04-2013, 06:58 PM | #36 | ||
Original Bumblebee Owner
Drives: 265hp ZX-14, 500hp Silverado, V-ROD Join Date: Apr 2009
Skip gears all the time. It would be rare for me not to skip.
Upshifting, downshifting, I just grab the gear the best fits the situation. Hell, there are 6 forward gears to choose from and buttloads of torque - LOL !!!
02-04-2013, 07:04 PM | #37 |
Drives: orange 2011 2SS/RS Join Date: Nov 2011
I don't get it, why didn't you buy an automatic if you don't want to work her through ?
ARH 1 7/8" Headers W/HFC, GM Performance Exhaust / K&N Typhoon CAI, Comp Custom Grind Dominator 3 Cam, Pioneer Dual Valve Springs, Trickflow Push rods, IWIS Timing Chain, Rapid Motorsports Tune, 496 RWHP
02-04-2013, 07:16 PM | #38 | ||
Yup, you don't get it...
I've been shifting gears for 45 years, I just somehow know which gear is the right one to select to match the conditions. Running up and then down all the gears is for amateurs... J.K. NOT !!!
02-04-2013, 08:11 PM | #39 | |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
Except when consciously holding the revs down on a cold engine, I rarely even glance at the tach. I suspect that I keep my engine running in a slightly tighter range of rpm for whatever the level of enthusiasm of the moment is, and I then select gears in accordance with that. Maybe that's a hold-over from a fair amount of motorcycle and "10-speed" bicycle riding in years past, but it is what it is. Norm |
02-04-2013, 08:47 PM | #40 |
disco kryptonite
1, 4, 6 or sometimes 1, 2, 4, 6
only when gettin' on it do I hit all the gears and 3rd more often gets used as passing gear from 6th than when up-shifting.
02-04-2013, 09:40 PM | #41 |
Drives: 2010 SS 426 V8 M/T Join Date: Aug 2012
02-04-2013, 09:41 PM | #42 | |
