08-07-2018, 05:13 PM | #1 |
Drives: ZL 1 2018, BMW M4 Comp. 19, Z4 M 06 Join Date: Dec 2017
Battery disconnected for Transport
Hello Forum,
hope the thread is here correct! I want ship my Camaro ZL1 6th. Gen. So the Broker want disconnect first the Battery. Here i need DIY and also a recommendation about it. Thank you Smudo |
08-07-2018, 06:11 PM | #2 |
Thank you Al Oppenheiser!
If the car is going into a shipping container for overseas transport, then yes they may require removal of the battery entirely (not just disconnection). May also require that the gas tank be emptied as well.
08-08-2018, 01:45 PM | #3 | |
and also fuel only filled max 25% you are right |
08-08-2018, 01:46 PM | #4 |
Retired from Car mfrs....
In the trunk on the right side, there is a door, pull hard on it , you won't break anything .....use a 10 mm wrench to reach inside with a flashlight and disconnect the negative cable. That's all you need to do
08-08-2018, 02:23 PM | #5 |
thank you glen E
