01-30-2017, 10:36 PM | #1 |
Drives: 2014 Camaro SS Join Date: Jul 2016
New TSP cam package!!!
Been lurking on this site for several months now since I picked up my 2014 SS. Tons of great info from all you guys and with that info I decided to give Texas Speed a call today and order up a cam kit. My car is a 6 speed and I made up my mind on the Stage 4 cam. When I was talking with the salesman, who was SUPER helpful, he informed me that they had been working on some new cams that were not being advertised yet. I was informed that this particular cam falls in between the stage 3 and stage 4, but outperforms the stage 4. This cam is claimed to be putting out 589 on their engine dyno. Here's the specs:
231/246, .641"/.615" 111+2 LSA. What are your opinions? Just curious to hear some thoughts on it. I already placed the order so its a done deal, but would still love to hear some feedback! Long tubes and CAI intake are on the way as well, and also ordered a trunion upgrade kit. One thing I went back and forth on, and ultimately decided not to do was replace the lifters. I am aware of whats involved, and based on the mileage of my car (35k), and the recommendation of the salesman, I opted not to order them. Do you guys think this is the right way to go? I'm not opposed to tearing the heads off but would rather not if its not a huge deal. I do hear some light ticking at idle and that has always concerned me a little, but the more I read up on these motors, the more I hear that this is normal. |
01-31-2017, 06:37 AM | #2 |
Drives: 2015 Camaro SS Join Date: Sep 2011
Nice !What was the TQ? Also do they have a dyno sheet to compare the area under the curve from existing cams?
2015 Camaro 2SS Cam/Heads/FBO 498/447 SAE |
01-31-2017, 07:37 AM | #3 |
Dan
Drives: 2010 Camaro 2SS IOM Join Date: Nov 2013
For what a set of LS7 lifters goes for - it is peace of mind especially since you have egine open...
Dan
2010 IOM SS YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust http://www.camaro5.com/forums/showth...&highlight=ysi |
01-31-2017, 09:18 AM | #4 |
Drives: 2011 SSm6 Join Date: Oct 2011
I like that cam choice.
01-31-2017, 09:27 AM | #5 | |
Drives: Black L99 2SS/RS Join Date: Mar 2014
http://www.camaro5.com/forums/showthread.php?t=408384 http://www.camaro5.com/forums/showthread.php?t=422881 http://www.camaro5.com/forums/showthread.php?t=297870 (This one below is actually a trunion failure) http://www.camaro5.com/forums/showthread.php?t=417111 These are just a few out of the very many lifters failures after upgrading the cam. With such an aggressive cam you've got there, I'm wondering why the sales rep tried to get you to potentially detonate your engine. If I were to cam my car, these are the only lifters I'd ever consider using. https://www.briantooleyracing.com/jo...lsr-32584.html Much rather pay the extra $500 and not $4,500 for an entire new block. |
01-31-2017, 12:28 PM | #6 |
Another thing I wanna add is one thing that kills lifters are excessive spring pressure and valve train setup, I didn't want to make it seem like a cammed car is going to explode sooner or later... Because ticking is definitely a normal thing for our cars.... I have longtube headers and a cold air intake, my car ticks.
...That being said however I'm too sure if the same thing applies to a cammed LS engine... hopefully someone who's had their LS cammed for a while can chime in. |
01-31-2017, 12:38 PM | #7 |
Drives: LSX FTW Join Date: Feb 2016
OP ls3 lifters are the same as ls7 lifters. You're low mileage so its not a necessity to change out, but if it gives you peace of mind go for it. I would highly suggest a trunion upgrade however with that cam. do yourself a favor and give brian tooley racing a call, not to bash on texas speed
#Gapped
01-31-2017, 09:42 PM | #8 |
Unfortunately I didnt get the torque specs! Damn, cant believe I forgot to ask that. I will give them a shout tomorrow and find out. Should be pretty decent I would imagine!! Im not sure if they have a dyno sheet yet to share as they are not even advertising this cam yet, but I will be sure to ask.
02-01-2017, 02:10 AM | #9 |
Drives: 13' 1LE Join Date: Apr 2012
Seems like a great cam...589hp is pretty intense!! Stock rockers arr very good. Try the new TSP rockers
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
02-01-2017, 10:52 AM | #10 |
Drives: Z06 Join Date: Oct 2009
For weeks now we have been making hundreds of pulls on our LS3/L99. We have just about finished up a complete line of new camshafts for both the vvt and non vvt motors. All of which have made more power than our own older setups and the other common cams out there. We will be making some more specific posts along with many comparisons very soon.
For the time being though, here is the dyno sheet for the 231/246 cam vs stock. We are using an l99 that we converted to an ls3 for testing, so we could easily go back and forth between vvt and non vvt. Because of that, the motor is down about 10hp even in stock form from where we see a normal LS3. Even with that in mind, the cams really pick up well from previous setups. |
02-01-2017, 05:26 PM | #11 | |
Drives: Savitar; The 500rwhp N/A Monster! Join Date: Aug 2016
*SOLD*504HP/433TQ | Night Fury cammed Cold Air Inductions intake Bo White ported TB Speed Engineering 1 7/8 longtubes NPP catback QTP low profile cutouts Powerbond 25% UDP 3.73 gears JRE scoop ZL1 grille R1 Concepts drilled/slotted rotors built/tuned by Weapon X Motorsports
02-01-2017, 09:37 PM | #12 |
I am hoping drivability is not too bad!! I expect to have some bucking down low as their tends to be with a big cam. I honestly do not care about it too much though as I will be distracted by the sweet sounds coming out the tailpipe!!!
02-02-2017, 05:24 AM | #13 | |
Drives: 2010 1SS Join Date: Aug 2015
2010 1SS LS3, Black, 235/250, .621/.615, 114 + 4, Kooks Stepped Headers, 3.91's, Bo White PTB, Flowmaster Mufflers, Cold Air Industries CAI, Apex Scoop & Windshield Washer Relocate, SLP Wheels, Skip Shift Eliminate, Barton Flat Stick, OEM HID/Halos, Dyno Tuned by ECS
02-02-2017, 08:34 AM | #14 |
Drives: 2013 1LE/SS Join Date: Mar 2012
Current mods: Stainless Power Long Tube Headers,Cat Delete,CAI Cold Air Intake,Vitesse throttle controller, Muffler/Resonator Delete w/dual tips. ADM Performance Tuned,BMR 1.25 lowering springs,R1 Concept Slotted/Dimpled Rotors.
