04-11-2020, 01:55 PM | #1 |
Drives: 2020 Camaro 2SS Join Date: Aug 2009
Turn rear view mirror cam into front cam.
Sorry if this has been asked already but couldn't find anything in the search.
I'm going to be taking a rear view camera i have laying around from my 2016 Camaro and add it to the front on my SS. My plan is to make a split in the rearview mirror cam line and create a male/female junction so i can connect which ever camera i feel like using. My question is has anyone does this yet? I've been away for a year with a mustang, but just missed my camaro to much and had to come back. In principal it should be pretty simple, i just have to find the easiest location to make my split. If i missed something in my thinking please let me know. I plan on getting to this in the next month or so and will post Photos when finished. in the meantime any thoughts? Last edited by chris227; 04-11-2020 at 03:03 PM. |
04-11-2020, 03:16 PM | #2 |
Drives: 2019 Camaro LT1 Join Date: Jul 2019
I would like to do this as well, I like your idea of splitting the video, i didn't think of that,"Thanks" I do have a video splitter for my FPV quad, So with the splitter, you can just pic what cam you want to look at, only thing is what triggers the rearview camera to come on the screen, is it done by a video signal are a trigger?
Saying THANKS don’t cost a dime so hand it out freely!
04-11-2020, 03:44 PM | #3 | |
04-11-2020, 05:23 PM | #4 | |
Drives: 2016 Camaro RS Join Date: May 2016
The camera connected to your rear view mirror is a “specific” camera. So you cant just connect any camera. So far, the cameras that can be used are either ones pulled from 2019-2020 spoilers, sharkfin antenna cameras on 2020s, or 2019+ Silverado cameras pulled from high mount stop lights. The poc cable uses connectors called “fakra”. I recently found a fakra video switch. I’ve been thinking of doing what you are attempting. I was able to get a camera that was pulled from a 2019 spoiler. Besides that all youd need is more wire to feed the new camera.
2016 Summit White 1LT RS, Brembo Brakes, NPP Exhaust,Front Glowtie, Rear Red Glowtie, Adrenaline Red Interior
04-11-2020, 05:38 PM | #5 |
OK so you have the LCD in your rearview mirror? mine is on my radio monitor. What i was originally going to do and most likely going to do, is I'm taking out the overhead that has my Onstar and pass airbag info, Put in one out of a 2018 that has the home link in it for my garage opener, then for my Onstar, on some older GMs they have a rearview mirror that has Onstar and an LCD in it that is easy to hooh up, I was going to hook my front camera in the rearview mirror and I would still have my backup camera and a front camera for cheap. I know there will be some rewiring and changing the mount on the mirror so it will fit in my car, but I'm cool with that.
04-11-2020, 05:52 PM | #6 | |
04-11-2020, 05:54 PM | #7 | |
04-11-2020, 11:25 PM | #8 | |
04-11-2020, 11:27 PM | #9 |
04-22-2020, 03:12 AM | #10 |
Drives: Chevrolet Camaro ZL1 Join Date: Nov 2019
04-23-2020, 04:47 PM | #11 | |
08-09-2020, 12:13 PM | #12 |
Small update...
I received the camera i was going to try from a 2019 Colorado, Unfortunately it didn't work. All i got was flickering white screen. It was worth a try for the price, i returned the camera and will be ordering the spoiler with camera. I did make a small RCA switch with parts i have lying around. I modified 3 Fakra Z cables to RCA and confirmed it works as a switch between cameras. I used a friends Camaro to test the switch by parking back to back and connecting both cameras to the switch. This should all be done by next week when i get my spoiler. |
08-10-2020, 09:48 PM | #13 | |
What are you connecting the rca to? Or are you just converting to rca so you can use an rca switch?
08-10-2020, 11:20 PM | #14 |
Converting the ends for the sole purpose to use a rca A/B switch. I spent $20 for the Fakra z cables and had the rca cables lying around. Made a simple small rca switch for nothing. Will mount under dash to be able to switch between cameras. After reading my previous post I noticed I failed to mention the switch I made.
