06-25-2020, 11:19 AM | #1 |
Drives: Blue ss 1le 18 Join Date: Apr 2018
Aligmnent for 305/35/R19 square
Gents,
I was a Laguna last weekend, trying out my new set of Apex wheels with goodyear S3R tire. I am very pleased with the new setup, however, I noticed a bit of under-steer in corner entry and the outer edge in front is wearing fast. Car is set with track alignment, ie -2deg front -1.5 deg rear and 0.1 deg total toe. It used to work great with the OEM 285 rims and tires, but I wonder if you put more camber with a wider front tire ? I DD my car so I will not go above -2 on front otherwise I will cord the inside, any thoughts on camber plates ? Also, tire pressures was 37 PSI hot, and I am running almost the same wheel offset as stock SS 1LE wheels (ET 11 front and ET 43 rear) Cheers TM |
06-25-2020, 11:39 AM | #2 |
ITCRNRS
Drives: 2018 ZL1 1LE Join Date: Jun 2012
I am running -3* front and seem to have good wear on track, I do flip mount my tires when need to use the other shoulder to get even wear.
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap |
06-25-2020, 12:51 PM | #3 |
Drives: 2019 1LE Join Date: Nov 2019
Info in here might help. https://www.camaro6.com/forums/showthread.php?t=575321
"That my friend.. is the sweet succulent sound of the car preparing to ignite the wonderfully tasty nectar your V8 needs to send the screaming bald eagles furiously from the 4 pipes out of the rear of your vehicle"
06-25-2020, 02:25 PM | #4 | |
Curious to know if anyone else is going higher then -2 on FA on a SS 1LE |
06-25-2020, 06:09 PM | #5 |
I don't daily it, but I do drive it to track and around some. Stock my wear was very good with -2.6F and 1.6R. Zero F toe. Now with the G3R square I'm at -2.9F and -1.9R and track wear is perfect. Rotating them helps a lot. This is after 12 x 30min sessions
06-26-2020, 11:51 AM | #6 | |
I will try to get closer to - 2.7 / 2.9 deg F for trackdays and go back to -2 F for DD. This is where a good camber plate can be handful. |
