06-27-2021, 07:44 PM | #197 | |
Drives: 2017 2LT Garnet Red Join Date: Dec 2011
Christopher |
06-27-2021, 10:21 PM | #198 |
Drives: 2022 Vert 2SS Join Date: Mar 2021
Bad night
Wish I could return with an awesome story of burnouts and neck snapping holeshots, but I have had buzzards luck. Put it in CF8 to go to Lowe's, ran fine, had me very eager to try the sport modes. I had fun for about 4 miles, and threw a code in Lowes parking lot, had to limp to a safe parking space. Ran in and bought a 10mm ratchet set or whatever, unhooked the cable and went back in for my paint to be mixed and to get my other supplies. Came back out, reconnected, started the car, dropped the top and said forget it I'm gonna cruise home soft and slow, disconnect it and read up on it some more. Made it about 1 mile down the road and went into limp mode Mind you, the top is down, which made it more difficult to get to the batt terminal in the trunk. Now I'm fuming. Coast into a G station, pop trunk, start disconnecting neg term- encountered resistance- and SNAP, the fvckin nut/terminal screw sheard completely in two. un. frickin. believable. I was kickin myself in the azz hearing my wife in the background tellin me to stop messin with this car. What do I do now? I can't start the car due to neg term loose, weird terminal connecter sheared in half, top down, 5 miles from home... |
09-10-2021, 01:37 AM | #199 |
Drives: 2021 LT1 A10 RS Join Date: Feb 2021
I just installed throttle controller.
Goods are as billed. My goodness what a difference. Ludicrous is just that. I like Comfrot 9, or SP 1 for LA city driving. The ECO 1 for valet drivers is a quasi valet mode too. If anyone has a recommendation on how to do a more tidy install, or taping of the line Id appreciate any comments. The lightning plug is pretty trick. |
09-22-2021, 10:24 AM | #200 |
Drives: 2015 Corvette Stingray Join Date: May 2019
Thanks, everyone.
09-22-2021, 01:32 PM | #201 | |
Drives: 17' 1SS 1LE GBA-Black Join Date: Mar 2017
I am also a customer of Mike, however, since buying the Controller and TB from him ~ 2 years ago, was not able to install it. Held up for a couple of personal reasons. Anyway, now I was just about to go ahead and finally install it and came across this old post, which I believe should be answered. Thanks for looking into this for the community and users/customers of the controller |
09-25-2021, 01:50 PM | #202 | |
Yes, it doesn't take much current at all for the ECM to call it a "short circuit", the threshold shown on the picture for Dodge is very similar to that of the latest Chevy's. Now, let's put it in perspective (relative terms); how much is too much? One could call 25mA razor-thin but the pedal sensors work at under 5mA, we are talking about 100's% so the razor-thin 25mA gives us a huge space to work on for we need much less than that to run either of our TC's. If you make a device that will consume anything near or greater than that, you have to go power it somewhere else. I think this is why and it's been portrayed as an advantage. The same is true for anything else, I'm sure you cannot draw any amount of current you want from the OBD2 port either, or similarly, one cannot do that at home either without tripping a breaker at some threshold amperage. There's a limit for everything. You work under the limit and you are safe. Also, some OBD2 devices are known for draining batteries, and that could be used as a scarecrow against any of those, but if a given company knows what they are doing there's no reason for them to drain your battery. Thanks, |
09-25-2021, 02:13 PM | #203 |
Thanks Mike for answering the question.
So we are completely safe with a 5 x safety margin if I it understood correctly? (25mA reserve Vs. 5mA actual current draw from the Soler TC?) |
09-25-2021, 02:45 PM | #204 |
09-25-2021, 07:49 PM | #205 |
Thank you very much, Mike, your response and especially putting the question into perspective is appreciated.
2018 Camaro 2SS G7E MX0 NPP F55 IO6
09-26-2021, 08:46 AM | #206 | |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
Changing the TB size requires a tune to gain max performance. The tuner changes the tables in HPtuners and the stock tables/values are no longer valid. Every tuner tunes a bit different, how does your unit adjust to all these different tunes? I can see your unit working for your desired gains if they where on just stock vehicles and the tables/values remained the same but I don't see it working on a different tunes. (Tables/changed #) Correct me if I am wrong and I am just trying to understand your unit.
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
09-28-2021, 09:16 AM | #207 | |
Total Change = Tune Factor x TC factor So the total change is now variable too. I.e. if the tune is too much, you can scale down it with the TC, if it was too low you can scale it up with the TC. |
09-28-2021, 09:44 AM | #208 | |
Do you have any test results? 60 feet times would be one example to see the unit in action. With the increase of pedal output you would see your 60 feet/1/8/1/4 times improve with your unit, any test runs? Videos?
09-28-2021, 09:46 AM | #209 |
Drives: Camaro 1SS A8 Vert Join Date: Sep 2018
Just remember, when they tune the car you have to disconnect the TC.
The TC will make it show a high pedal voltage value, putting car in limp mode. When the tuning is done, put TC back in and all good. |
09-28-2021, 10:04 AM | #210 |
BlackbeastSS2
Get the new DLX TC and you will not stop grinning. The TC just just clean up your throttle response and tailor to how you want the car to react. On the new DLX the setting SP5 is a one to one like having a throttle cable. That makes it worth the money. I have never did test or videos of my 60 foots,but I would guess its good for 4 or 5 tenths. Its like highend guns with trigger jobs,the lighter and shorter the reset the quicker you can shoot. |
