07-27-2018, 04:58 PM | #15 |
The BBOMG fill-in husband
Drives: 2015 2SS/RS 1LE AKA V1LE Join Date: Aug 2010
Mine works, same one, maybe a bad one
UPSTATE C5 MEMBER
07-28-2018, 06:53 AM | #16 |
376 cubic inches of fun
No it doesn't. Driving around the block will restore the pressure readout, but if you have swapped wheel positions, the readout will be from the old positions not the new ones.
That is the whole point of the re-learn procedure. |
07-28-2018, 07:43 AM | #17 |
Drives: 2014 2SS blue Join Date: Jun 2016
Put the driver in learning mode, walk around the car twice, push the driver door lock button twice for 1/2 second each time, turn the key to on, honk the horn 3 long blasts 2 seconds minimum, say "sum bitz, sum bitz, sum bitz" loudly into the overhead microphone, start the car, drive to the tire shop, put the driver in beg mode, fixed.
07-28-2018, 09:08 AM | #18 | |
Drives: 2010 1SS Join Date: Aug 2015
2010 1SS LS3, Black, 235/250, .621/.615, 114 + 4, Kooks Stepped Headers, 3.91's, Bo White PTB, Flowmaster Mufflers, Cold Air Industries CAI, Apex Scoop & Windshield Washer Relocate, SLP Wheels, Skip Shift Eliminate, Barton Flat Stick, OEM HID/Halos, Dyno Tuned by ECS
07-28-2018, 09:17 AM | #19 |
Drives: 2015 Topless Btch RS Join Date: Mar 2016
Mine works with a battery
07-28-2018, 03:25 PM | #20 |
Drives: 2014 Camaro 2SS/RS Join Date: Jan 2017
Thx all od You...probably have a bad one...did everything correct, tested 2 new batteries too...
07-28-2018, 03:45 PM | #21 |
Drives: 2014 1le 1SS CRMT Join Date: Apr 2014
I bought one off Ebay works perfect
07-29-2018, 10:57 AM | #22 |
Your in Poland, your TPMS sensors might be a different frequency...
07-29-2018, 11:30 AM | #23 | |
Drives: '10 Camaro SS,Jeep Commander Hemi Join Date: Mar 2010
it works fine!
07-29-2018, 01:20 PM | #24 | |
Even here in the US, I had to stop a tire shop from installing sensors that worked with their proprietary tool but not the GM specified tool. Can of worms. |
