Old 12-27-2023, 10:13 PM   #1
_Onyx_Wolf_
Onyx_Z7 <— Instagram
_Onyx_Wolf_'s Avatar
Drives: 2013 2ss 1le
Sunroof leaking by drainage tube?
Anyone ever have this issue? Been chasing this issue for weeks now and can’t seem to find out how water is leaking through the plastic in the sunroof. Other drain is fine but the passenger side drain is the one leaking. Filled the passenger side drain with water and it seems to drain fine then stops. Im guessing the water might be sweating through the plastic since it has no place to go??. Tried water proof sealant, flex a seal, etc and it’s still getting through. Any tips would be appreciated lol
427 Dart block, M311 Heads, Pat G Custom Cam, ATI Balancer, BO White Stage 3 TB, Custom CAI, FI Tech Sheet Metal Manifold
_Onyx_Wolf_ is offline   Reply With Quote
Old 12-28-2023, 07:29 AM   #2
Wizard1183
Wizard1183's Avatar
Drives: ABM SS2/RS M6
Send a message via Yahoo to Wizard1183
There’s a leak. Water doesn’t sweat in one spot. It’s hard to see in pics where it’s be leaki by from? My guess is above the hose. Or at the hose. You sure the hose isn’t clogged? Wish you hadn’t flex sealed it. Why would you do that if it’s not cracked? There’s a drop of water on the hose. Its either the hose or they housing. Replace the housing.
Life is short, drive it like you stole it!
Wizard1183 is offline   Reply With Quote
Old 12-28-2023, 09:43 PM   #3
yellow69z28rs
Drives: 2013 ZL1 Convertible Black
Send a message via AIM to yellow69z28rs
You said "it seems to drain fine then stops"
If its draining "fine" then you should see all the water running out onto the ground at drain hose exit underneath the car,
If its "draining fine then stopping" the hose is most likely clogged near the bottom at the exit and the hose fills with water, which makes it seem as though its draining, But all its doing is filling the hose up and the water is leaking into the car at or near the connection you show in the picture.
JRE 750 HP package
Rag Top Rob
yellow69z28rs is offline   Reply With Quote
Old 12-28-2023, 09:51 PM   #4
_Onyx_Wolf_
I’m thinking this I’m going to try and use an air compressor and blow it out
Old 12-28-2023, 09:53 PM   #5
_Onyx_Wolf_
My thought was their was a hairline crack or something so I figured a sealant would seal it up lol. Thinking it’s a clog at the bottom of the tube
Old 12-29-2023, 08:24 AM   #6
SummitWhite11
SummitWhite11's Avatar
Drives: 2010 2LT/RS
So it's draining through the sunroof plastic which is the sunroof shade you mean? Only thing I know of from experience and others is water forming a puddle from it draining into the rear trunk. But the roof?? Hmm...
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), FRONT/REAR Carbon Fiber Wrapped Bowties, Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Side Faded Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links. Evil Energy Catch Can.
SummitWhite11 is offline   Reply With Quote
Old 12-29-2023, 08:31 AM   #7
Wizard1183
Wizard1183's Avatar
I think hose is clogged
Old 01-02-2024, 03:21 PM   #8
_Onyx_Wolf_
For those wondering blowing out the tube that drains from the sunroof with an air compressor fixed the problem. Water now exits through the side of the door jam area. Thanks everyone for the help!
Old 01-03-2024, 05:04 PM   #9
SummitWhite11
Drives: 2010 2LT/RS
Glad you were able to resolve it!
2010 2LT/RS
