10-04-2023, 09:32 PM | #1 |
Onyx_Z7 <— Instagram
Drives: 2013 2ss 1le Join Date: Aug 2014
Where does this plug go? LS3 IM
I’m drawing a blank and can’t find where this plug goes 😂 does anyone know it’s the fuel injector wire one
427 Dart block, M311 Heads, Pat G Custom Cam, ATI Balancer, BO White Stage 3 TB, Custom CAI, FI Tech Sheet Metal Manifold
10-04-2023, 09:46 PM | #2 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
Is that the stock wiring harness to your 1le?
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
10-04-2023, 09:55 PM | #3 |
I believe so yes
10-05-2023, 03:32 AM | #4 |
It could be a afm/dod harness from another car.
10-05-2023, 05:19 AM | #5 |
Looks like the MAP sensor connection. The MAP sensor should be behind the throttle body pointing towards the passenger fender.
2014 Camaro SS L99, Ashen Grey w/Black Leather - Build thread - http://www.camaro5.com/forums/showthread.php?t=491561
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
10-05-2023, 05:22 AM | #6 |
Drives: 2010 Camaro SS , 2011 Colorado LS1 Join Date: Jan 2022
Agree with Ashen 6.2, this is the MAP sensor plug.
10-05-2023, 06:11 AM | #7 |
Drives: 2013 Camaro 2SS AGM Join Date: Apr 2020
Looks like the map to me also. The black/white must be the 5v ref. but it shows up in the ground distribution as well.
2013 2SS GPI built & tuned 415, spec'd by Andrew Cammer. GPI ported intake/tb/heads, Tooley springs, CHE trunnions, Callies rotating assembly, Diamond pistons, GPI SS3 VVT, ATI 10% ud damper, Circle D 3800, Kooks ceramic coated lt's with green cats, Mishimoto rad & oil cooler, Derale trans cooler, Holley efi rails.
10-05-2023, 06:59 AM | #8 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
Agreed. There's only one plug on passenger side that looks like that.
10-05-2023, 09:55 AM | #9 |
Thanks guys ya I think that’s it I gotta look back at my old manifold and see if the map was connected to that when I took it off.
