09-18-2023, 05:31 AM | #15 | |||
Drives: 2022 Rapid Blue ZL1 Join Date: Feb 2022
Deleting the OEM oil cooler requires removing the coolant line from the water pump. Improved racing sells a delete kit, but the cap for the OEM radiator hose doesn't fit and I didn't like a rubber cap idea anyway. I used the water pump block off plug in the kit, but made my own solution for the lower radiator hose. The OEM hose is just a coupler with a Tee coming off to return the coolant to the system. I just removed the tee and installed a 1 1/4" straight coupler.
2022 M6 Rapid Blue ZL1
Performance: Kong X-Port OEM blower, 1 7/8" TSP headers (Polydyn coated), Corsa Intake/X-pipe/NPP Exhaust, LT5 95MM TB, DSX FlexFuel sensor, Dedicated Motorsports inline fuel filter, Katech Dual fuel pump, WeaponX Boost freeze chiller, WeaponX center and aux HX, PWR oil cooler, and Elite E-2X catch can. Tuned by Pat G 731 WHP on a Mustang Dyno. Suspension/Brakes: Eibach lowering springs, Vorshlag camber plates, Full SPL rear control arms, DSC Sport suspension controller, Blackwing F/R brake cooling ducts. |
09-18-2023, 07:41 PM | #16 | |
Drives: 2019 ZL1 1LE Join Date: Feb 2017
Old: 2017 SS 1LE
Old: 2017 ZL1 Current: 2019 ZL1 1LE |
09-29-2023, 08:24 PM | #17 |
No problem, happy to help. Let me know if you have any other questions.
03-04-2024, 04:55 PM | #18 |
Drives: ex-wife's car Join Date: Jan 2011
Very clean install and great idea! What fittings and hose brand did you use?
