07-25-2020, 12:52 PM | #1 |
Onyx_Z7 < Instagram
Drives: 2013 2ss 1le Join Date: Aug 2014
BMR non adjustable rear control arms question
currently am lowered on a bmr split drop if I can remember correctly 1.5 front and 1 in the rear. Looking at adding coil overs bc my car is way too low for my liking since I added a front splitter. Looking at getting afe adjustable coils and still want to keep that raked looked just not as low in the front. So if I say drop the back less than an inch maybe .5 would the non adjustable bmr lowers still work??
07-25-2020, 06:53 PM | #2 |
Drives: 2015 Z/22 Join Date: Aug 2015
The adjustability would only be necessary if you're lower so much that you can't achieve proper alignment specs. If you're going closer to stock height the non-adjustable arms will be fine. I'm lowered over an inch in the rear (1.25" or so) and am running the factory LCA's with -0.5° camber - if I want more I have JPSS's eccentric bolts to allow for more adjustment.
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
07-25-2020, 08:14 PM | #3 | |
Onyx_Z7 < Instagram
07-27-2020, 04:11 PM | #4 |
Drives: Race Car Join Date: Sep 2009
so you should be OK - you might need a Camber Bolt kit
07-27-2020, 08:50 PM | #5 |
Onyx_Z7 < Instagram
07-28-2020, 03:42 PM | #6 |
There are some coilovers ( which have a Reserve canister) that they do not fit
07-29-2020, 01:33 PM | #7 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
07-29-2020, 03:51 PM | #8 |
Onyx_Z7 < Instagram
Looks like the afe featherlights have a concentric intergrated remote canister
07-29-2020, 04:15 PM | #9 |
Not sure what the deuce a concentric integrated remote canister is, but judging by the picture of those coilovers you'll be fine. I think BMR is referring to such coilovers as these: https://store.jdpmotorsports.com/pro...table-042430-d, where there is a separate oil canister/reservoir which allows for greater travel, reducing chances of bottoming out.
