03-02-2020, 07:49 PM | #15 |
Drives: 2012 ZL1 Redline Phase 4 Join Date: May 2017
Sucks either way but much better off with an upper tap rather than a lower knock. Good Luck and as the saying goes, JUST COME BACK BIGGER AND BADDER
2012 ZL1 w/Redline PHASE 4-ZL Performance Package
03-02-2020, 08:23 PM | #16 |
Dude, you have had the absolute worst luck lately with this car. It really sucks to see this, I feel bad for you man. What was your normal idle pressure? I know each car is different. For instance with my new HV pump I idle at 42 psi and get up to 62 psi through the rpms. You look to be at about 10-12 psi.
Did you buy this car with a lot of modifications already or did you do them all yourself? Not insinuating at all, I am just curious if you inherited someone else's problems. What was your mileage when you cammed it? I hope your CHE's had nothing to do with this. I have a set on the way for my cam swap. I seriously recommend you don't start it anymore, and certainly don't drive it. Seriously, just one more time can do it in and you don't need that. Let the shop take over from here.
03-02-2020, 08:57 PM | #17 | |
Onyx_Z7 <— Instagram
Drives: 2013 2ss 1le Join Date: Aug 2014
03-02-2020, 11:01 PM | #18 |
Drives: 2013 2ss hotwheels Join Date: Aug 2014
I was just reading about this on a cam install. it said if the camshaft thrust plate is loose or worked loose ,or the Orange O real seal is missing or damaged a loss of oil pressure will result, It will sound like loud marbles getting sucked through because it's sucking air with the oil I'm probably wrong just thought it were my 2 cents worth in.
03-02-2020, 11:02 PM | #19 |
It also said if counter sunk boats were used and overtalked it could have cracked it the cover
03-02-2020, 11:21 PM | #20 |
Actually just received my new plate today, countersunk OEM version. I'm going to make sure to red loctite that sucker.
Hopefully that is his issue or even less. I mean aside from having to remove the crank pulley, water pump, and front cover, and assuming it didn't allow the cam to walk too far. Should be an easy fix. Hopefully.
03-03-2020, 07:35 AM | #21 | |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
Whipple 2.9 CAI ID1050x injectors ZL1 Pump JRE FPCM JMS Voltage booster JRE Rough Idle blower cam BTR .660 springs CHE trunnion kit 1 7/8 Speed Engineering Borla Atak JRE scoop 1.5" lowering springs BMR trailing arms and toe links Cradle inserts 704WHP 603WTQ 93 octane
03-03-2020, 07:40 AM | #22 |
I've seen a few cam lobe failures on aftermarket cams that were not installed by the owner but by a shop. There seems to be this misconception out there that you don't need to break in a roller cam because it is roller, I don't believe that and have a feeling that is what is causing these cams to wipe lobes after 5k miles. If you need a cam be sure to follow a proper cam break in period. If it's the CHE trunnion kit let me know I have these installed as well. Thy made me a little nervous as the bushings did not press in, they fell right in the rockers. Now that may be by design as they have oil grooves cut out so maybe they are better at riding on a film of oil. They all went in exactly the same and all felt the same like they had a tiny bit of play. I will be keeping an eye out, or ear out and that will be the first thing I check if I have an issue.
03-03-2020, 08:46 AM | #23 |
Drives: 2015 2ss Join Date: Jun 2009
hopefully just a broken spring as others have said, a simple compression test will tell you which cylinder it is. you could also try to VERY QUICKLY tap each exhaust runner with the back of your fingers to see which cylinder feels cold, that may help you speed up the diagnosis vs pulling 8 spark plugs to test.
good news is you still have oil pressure, hopefully it's a quick fix.
2015 Camaro 2ss, NicKey Performance built/tuned |
03-03-2020, 10:11 AM | #24 |
Thanks guys yeah I’m hoping for just a spring lol I have dual springs I believe so they should of held up? And I’m guessing if they failed is because I didn’t change them they had about 40k miles on them. Also here’s a video of it reving. https://youtu.be/0ytm0PDs-Rg
03-03-2020, 11:01 AM | #25 | |
I was thinking about using the red so the bolts stay put without any thought to next time I need to remove them. Yea, red may be a bit much. What did you use on the cam bolts?
From what I have read the CHE's are described as a floating bushing design, so that is normal and why they are considered a 'DIY at home' kit, with no press needed. Just that Circlip holding it in. I am just hoping those are some seriously premium circlips. As for break in, I am already running high zinc content conventional Valvoline VR1 10w30 (per my builder's recommendation) since I had this engine rebuilt 1400 miles ago. I was going to switch to a normal synthetic at 1500 miles, but I will ask Ryan his recommendations for oil once I get the rest of the parts. I am hoping he just tells me to keep running this for a little while longer as a case of 6 qts is only $40 on Amazon and I have some left still. Valvoline also make a synthetic VR1 with the same zinc additive package, but I was considering going back to Mobil 1 EP 5w30. Ryan/GPI is remote tuning mine, so no dyno break in/oil change after like normal. I will have to see what he says about intervals right after the swap. I don't know what a normal oil change schedule would be for when a dyno isn't involved. I don't think I am wording this right. You know how most places will change break in oil after the initial dyno pulls are done and then again at like 500 miles for example?
03-03-2020, 11:42 AM | #26 | |
03-03-2020, 12:52 PM | #27 | |
This is going to sound stupid, but I just want to be clear so I don't misunderstand. This is just after first start, no load on engine, 25 minutes 1800-2500 rpms varying the rpms in intervals while PARKED. Similar to an old school solid lifter build, right? Those instructions sound very similar to old school solid lifter cams, so I don't think you can go wrong there. Some people would say it is unnecessary, but I figure at the least it won't do any harm and at best...it saves your lobes/lifters.
03-03-2020, 01:23 PM | #28 | |
